need a mount for this light for a 35mm bar, most mounts I'm seeing only go to 31.8mm.
anyone help? would like a top cap solution if possible.
cheers in advance for any help
regards
tb
I ran into this issue too! Settled for no rubber shim and half a wrap of adhesive cloth rim tape. No ideas ref top cap though 🙂
Hi
yeah have tried with no rubber inserts but the bolt is then not long enough & doesnt go to the screwhole. hmph. I can put a bit further along the bar & fits but then it is too far over from the centre of the bars & loosens very easily.
cheers tom
thanks for those links, a great help 🙂
I just fit my light's off the central bulge. ie as the bar tapers to 31.8mm. Works fine for me.
