I've just bought one of these:
I assume I'm being a bit thick, but it looks like you need a 4 mm hex key to use the chain splitter.
But, I can't see how to remove the chain tool or the relevant hex key from the multitool so you can use them together.
Am I going to have to carry an additional 4 mm hex key too? 🙄
You can pull the tyre levers off the side of the tool and there is an allen key there.
Thanks Hobster 😳
Cracking little tool, but keep an eye on the bit that prods the pin on the chain extractor. Mine has come away from the outer threaded bit. I keep forgetting to glue it back in, I'm going to lose it one of these days...
Mine did that
I did that
Get on with it then!
