Too much Sealant?
[Closed] Too much Sealant?
5 Users
Having trouble getting some Trail King (New rubber queen) protection's to hold air on my crests. They seem to be leaking from the bead.
I put a bit More than suggested sealant in and they still wont hold. Is it worth putting a bit more in in increments or should I stop and take a different tact?
Posted : 12/12/2013 11:07 am
pump them hard to make sure the beads are seated and then hold them flat and slosh the sealant around - it should seal the beads. then turn over (the wheel, not you) and do the other side.
If it's still not sealing I'd leave it in a warm room for 24 hours and try again.
Posted : 12/12/2013 11:09 am
My Rubber Queens leaked enormously for the first few rides,was just a case of waiting and reinflating from time to time... and as wwaswas says, just make sure they're fully beaded on as that would also cause leaks from the bead.
Posted : 12/12/2013 11:18 am
Air compressor bang them up to 60psi and slosh the sealant around
Posted : 12/12/2013 11:21 am
they seem sealed but I might bash a bit more air in and leave them for a few day, Cheers
Posted : 12/12/2013 11:25 am
Pump them up and go for a quick spin around the block. I find riding them helps set the beads.
Posted : 12/12/2013 11:29 am
