Token vs Wheels MFG...
[Closed] Token vs Wheels MFG BB86
7 Users
Assuming I don't perfectly trust the BB facing in my canyon frame, which would you buy - the token at circa £50, or the wheels ABEC 3 at circa £80. I'm not paying £200 into hambini's pocket.
Or would you just fit a Dura Ace and some expanding sealant of some kind? I worry about later removing the BB with this strategy?
Posted : 07/03/2021 5:39 pm
Someone has also told me there's a Praxis option, but it appears all of their 24mm BB's are externally threaded and so not suitable for a BB86 frame.
Posted : 07/03/2021 5:44 pm
Very pleased with the Token installed in my Norco Search XR Carbon, installed after a year. The dealer said the he fits them to all his personal bikes, whatever genre.
Posted : 07/03/2021 6:31 pm
I use a token ninja in my canyon carbon frame - it got rid of the annoying creak of the press fit shimano bb. A carbon frame with no aluminium insert for the bb is a recipe for creak city. No problems to date.
Posted : 07/03/2021 7:01 pm
I had a wheels mfg press fit bb that screws together on my old bike and it was spotless! I was going through Sram gxp bb’s really fast but I had no issue with wheels one, I’d get one again.
Posted : 08/03/2021 8:21 am
I have both and they are equally as good. Take care fitting the Rotor, they have plastic top hats a bit like old HT2 and the ham fisted can break them during installation.
FWIW, the Rotor is cheaper than the Wheels but you can't tell.
Posted : 08/03/2021 9:32 am
@finbar Those aren't thread together, just alu cups to be pressed in.
@boblo The rotor also isn't thread together.
Posted : 08/03/2021 12:05 pm
@boblo The rotor also isn’t thread together.
Mine is. 👍
Posted : 08/03/2021 1:38 pm
@boblo https://rotorbike.com/catalog/default/rotor/road/bottom-brackets/bb86.html
None of those are thread together. As I said in the first post, the Canyon frames are BB86. Have they discontinued your model or do you not have BB86?
Posted : 08/03/2021 4:10 pm
Correction for my post, I have the Token Ninja replacing the BB86. Definitely screw together.
Posted : 09/03/2021 12:13 pm
Different application, but I have a Wheels Manufacturing thread together BB on my fat bike - quick and easy fitment, and now creak-free. 24mm axle, 41mm dia, 121mm BB width... Can't recall if it's ABEC-3 or ACB...
Posted : 09/03/2021 2:19 pm
