Titanium frame desi...
[Closed] Titanium frame design..
5 Users
Im having a prototype Ti frame built for me and I need help with the tubing specs, whats typical for a trail bike for example, I have a fare idea, but I could really do with more info...My knowlege is steel based, havn't worked with Ti before..Should I be matching pretty much the wall thicknesses for steel?
Be great if any designers on here could chip in?
Also there was a guy who designed and got a frame built for himself in the far east on here, he had a blog about it but I cant find the link, anyone know what Im talking about?!
Thanks a mill for any advice that anyone can give, much apprieciated.. 😀
B
Posted : 14/01/2010 11:57 pm
Ahh, hello, that could be me then...
[url= http://www.spanner.org.uk ]Spanner Bikes[/url]
Feel free to drop me a line via the contact page on the blog,
Cheers,
Andrew.
Posted : 15/01/2010 6:52 am
 cy
If you're used to building in cromo rather than fancy steel, then like for like on the wall thickness is a good start. You need to think about stiffness though. As ti is half the stiffness of steel, you'll need to go up a tube size on most of the tubes to get the level of precision you'll want for trail riding.
Posted : 15/01/2010 9:25 am
min of 34.9 top tube / 42mm down tube if using 120mm + forks - even that will feel whippier than most current steel frames. ti tubes tend to be available in the same wall thickness as cr-mo so up the diameter to keep the stiffness. i have a few butted and PG ti frames, i generally prefer the stiffer PG versions but in reality diameter affects stiffness more effectively.
Posted : 15/01/2010 9:50 am
I'm pretty amazed that Cy and James have been quite so detailed in their replies. That's really very nice of them!
When you buy a Cotic or a Genesis frame, this is the expertise that you pay for.
All I say is that there's quite a lot more to it than wall thickness and diameter, and a frame will break at the weakest point 😉
Posted : 15/01/2010 10:03 am
Andrew, Cy, James and Brant, thanks a lot for replys...
Andrew I will be in touch with you later today...Your site has been really really usfull..thanks
Cy and James, Ive built my own proto's up till now with a mix of crmo and fancy tubes. but i get what you mean alright..Will be going with Plain guage as its a good bit cheaper for this early stage of development and i dont mind the extra weight because it'll still be way lighter than the steel versions ive built...It'll be a bit stiffer too..
Am well aware of how much diameter affects stiffness and the maths there of..Good recomendation on the min diameters....thanks a lot...
Brant i guess the weakest point may be the designer 😀
Posted : 15/01/2010 1:57 pm
