Time ATAC pedals
[Closed] Time ATAC pedals
38 Users
I'm on Shimano Saints currently and have been on Shimano SPDs for years, I generally like them and the bombproof reliability. However, with it being all slippy and that lately there is a trail we do regularly that has about a million slippery corners that really benefit from hanging a foot out. I'm not bad at banging my foot straight back in but not 100% and wearing the winter Northwaves the sole has sod all traction on the cages so have hit a few jumps and stuff unclipped which I don't enjoy much.
Have read up a bit on the Times but have a few questions - are they better at engaging when you stamp your foot in the general direction of the pedal than the Shimanos? What is the cage support like when you miss - read they are smallish and no pins so not great? And would I be best off going for the Atac DH with the alloy body if I do take the plunge? I am a bit of a pedal smacker and on an ebike so weight not a concern, think they are about the same weight as the Saints anyway
Any other suggestions? Heard too much bad stuff on the Crank Bros. Maybe I should have kept my old DX636 with the rotating cleat. Yes, I do fancy a change, it is possibly for the sake of it and I don't want to regret it....
Posted : 12/01/2021 2:23 pm
i tried a few different pedals, new to clips.. I'm a massive fan of the DMR V-twins, the cage being able to rotate slightly as you clip in.. they work quite well for me beign a newbie.. in and out
decent platform, and pin configurable
Posted : 12/01/2021 2:30 pm
 Bez
Long time since I used Shimano but (IME at least) there’s no massive difference in terms of getting in or out, and no cleated pedal is going to play nicely when you’re not clipped in. But then I’ve tried very few caged cleated pedals.
For my money it’s a choice between staying clipped into whatever cleated pedals you’ve got, or using flatties. YMMV.
Posted : 12/01/2021 2:33 pm
Have ridden flats plenty but prefer clips. Just looking for least worst option for hanging a foot out when required
Will have a look at the DMRs
Posted : 12/01/2021 2:36 pm
A long time Time user here and recently moved to shimano.
I think shimano are better in every way.
More positive in engagement, less slop/movement once clipped in and no harder to remove in my opinion.
Posted : 12/01/2021 2:46 pm
I've never used the MX and Speciale Time pedals but I've been using ATACs since my Eggbeaters went phut on a ride home in the dark. The ATAC's are an easy clip in for boots, the brass cleats are very soft and the normally unclipped foot side will wear very quickly leading to more float (handy if your knees are fragile). Always have a spare set of cleats handy if you go with them as the law of Sod will mean that you will need one just as the shops close for an upcoming ride.
Posted : 12/01/2021 2:50 pm
I've got 2 old pairs of Time pedals in the spares box, Z-Atac or something IIRC, would post out for a fiver charity donation + postage if anyone wants them?
I'll post a pic if needed
Time ATAC user here since 2003-ish. No complaints whatsoever. First set lasted until 2016 I think. Since then I've run different ATACs on different bikes (road, MTB and gravel) but get on with them all.
The only weirdness I've experienced is a bit of play that I doesn't seem to be coming from a pedal or a cleat or a shoe, so I really don't know what's causing it. No issue though.
Posted : 12/01/2021 3:08 pm
Regarding unclipped stability/grip, I'll say that's pretty much a myth. I'm yet to find a clipless pedal/shoe combo that provides any meaningful utility when unclipped. Worse, pins like on the Saints have the effect of making clipping in harder when you're in a hurry. Take a look at EWS pros and you'll see plenty of big pedals with pins removed.
I've come to the conclusion that the cage usefulness is to maximise stability and contact area when clipped in, which really is where you want to be with clips. For example, I've had SPD Saints some years ago and now have XT M8120s, both on AM7 shoes. The XTs provide the same contact area and feel when clipped in as the Saints but are much easier to clip in. I much prefer the XTs
Posted : 12/01/2021 3:19 pm
I was in a similar situation to the OP - been on Shimano SPDs for years, and then tried some Time Speciale 8s which you can read about here: https://singletrackmag.com/wp-content/uploads/2019/11/time-speciale-8-atac-pedal-review-pretty-much-perfect/
Basically, it's going to take a lot for me to go back to Shimano. The clip in action is definitely easier/more natural on the Time pedals. I've not ridden Shimano Saints (I was on XT Trail) so can't compare the unclipped grip, but yeah, the Time's aren't amazing in this respect. Having said that, I found them so much easier to clip into, I rarely rode them unclipped.
The only issue I've had was a rogue rock hit and damaged one of the clips. I ride in the Lakes though, so flying rocks are a regular occurrence, otherwise I can't fault them.
Posted : 12/01/2021 3:21 pm
Nobeerin the fridge could you stick up a pic but I could be very interested, my old times have just died
Posted : 12/01/2021 3:46 pm
No worries, will do
@karnali, I had a look, I may have thrown them out! sorry, If I come across them, I'll PM you.
Posted : 12/01/2021 3:48 pm
I'm back using the Time ATAC Carbon XS pedals bought in 2006, with my newish PX Das Boots and a new set of Time cleats... They don't make things like they used to!
Posted : 12/01/2021 3:49 pm
MX-8 user here - absolutely excellent engagement even in extreme mud. Also - the build quality is still pretty darn good, I've got some x-roc's on my daily hack bike which must be pushing 15yrs with zero bearing play...
Posted : 12/01/2021 4:00 pm
Long time Time pedal user here no complaints at all they've always been entirely faultless for me the cleats do seem to wear reasonably quickly though.
I typically run the cleats the wrong way round for a bit more play.
I've got a mixture of versions including the expensive aluminium things that look like big platforms and they all just feel the same underfoot as far as I can tell.
Posted : 12/01/2021 4:01 pm
Dave - not sure what you’ve heard re crank brothers but it sounds like the company of old. My Highline dropper has been faultless for three years of continuous use and both my mallet DH and mallet enduro have been great. I’ve just done a bearing service on the DH pedals using the crankbrothers kit, it takes 20 mins for both pedals and they’re like new, bar the battered cages. So I’d say get some Mallet DH, they’re perfect for the moments you describe and the clip mechanism works very well. Might take you a few rides to get used to float as opposed to the in/out nature of shimano but that would be the same with Time.
Or the HT pedals are supposed to be good and use a similar clip to shimano.
Posted : 12/01/2021 4:07 pm
As above. Used them for years, kind to knees, engagement is v easy until cleats wear a lot, they wear quite quickly and are quite expensive for what they are.
Agree it's definitely the case that the pedals are not built as well as they used to be. Early pairs lasted ~ 10yrs with no maintenance (you can't get into them I don't think to replace bearings - maybe the mega expensive top of the line ones). I had some ~2yr old ones eat themselves (bearings) 1/3 of the way into a big skidaw loop ride with mates this autumn which wasn't ideal!
Posted : 12/01/2021 4:10 pm
Steve - I did hear they had improved but also read a couple of reviews that said that the engagement mechanism makes them harder to clip into than SPDs, not your experience?
Posted : 12/01/2021 5:00 pm
I used to have the older version of these - https://www.merlincycles.com/time-atac-mx4-mtb-pedals-112760.html?utm_source=PHG&utm_medium=AffiliateMarketing&utm_campaign=phg-GB&ucpo=49163&source=PHG
They were bombproof - had them 5 or 6 years never once looked at the bearings.
I went back to Shimano as I could kit out 3 bikes & not need loads of different shoes for the price of one pedal
Posted : 12/01/2021 5:12 pm
Last Crank Brothers I had were a lot better, no bits fell off, bearings are good quality now. But kept finding either my shoe would slip forwards while trying to clip in and/or the mechanism would roll over inside the cage and not catch properly. No doubt someone will say my technique was wrong but that just doesn't happen with Shimano for me. Would like to give Time a go, find out if the float helps my knees.
Posted : 12/01/2021 5:25 pm
I switched to Shimano from some very old ATAC, only because I found a cracking deal on a pair of XT pedals.
I reckon engagement and float are better on ATAC, and as mine lasted 10years+ I think the quality was fairly decent👍.
I'll probably switch back in another 10 years as these XT seem bomb proof too.
Posted : 12/01/2021 5:38 pm
Steve – I did hear they had improved but also read a couple of reviews that said that the engagement mechanism makes them harder to clip into than SPDs, not your experience?
In all honesty it’s been too long since I’ve used shimano to comment. I don’t have any issues clipping in with five ten or specialized shoes in either rubbish or decent conditions. I do use the supplied plastic shim underneath the cleat.
Posted : 12/01/2021 5:45 pm
If going Time I’d go DH4’s - I considered them last time but wanted to keep Shimano spd compatibility. I used to have Time atacs back in the day and those were less picky on placement of cleat to get clipped back in than Shimano.
In the end I went with Nukeproof Horizons but I have removed a couple of pins from each. They now clip in really easily but if you don’t have a chance they have enough pins to grip your foot better than any other spds I’ve used.
Just a thought though - if you have shoes with chunky soles they don’t tend to work well with spd pedals that have pins. I had some xc style Shimano shoes and they didn’t play nicely - however my Shimano AM7’s work brilliantly with them.
I went from Shimano to Time Atac. IMO one of the best upgrades you can do.
Shimano's clog up with snow or mud and you can't clip in. You know when someone is riding Shimmano's when you hear the clattering of shoes banging against the side of the pedals. You have none of that with the Atac pedals no matter how grim it gets.
Secondly Shimmano's don't have enough float so any twisting and shape pulling and you're unclipped without warning. Either slow descending where you need to bounce the bike around or shape pulling off jumps and drops the Atac's are more suited.
On the downside if you take a bad rock strike on the spring of the Atac's then the clip gets a little bit of play in and you have to replace them because you can't fix or service the spring, but they're cheap enough to replace without moaning about it (but then the Shimmano's aren't without their mechanical issues, especially the higher end XTR's (which they may have resolved now).
I'd never go back to Shimmano's now.
Posted : 12/01/2021 6:33 pm
A long time (20 year) Time user here and moved to shimano Saint before last winter. I'd started repeatedly bending Time bars with rock strikes and it was getting expensive as they're no longer repairable (bent an axle too but they can be swapped out)
Saint definitely have a much more solid feel underfoot when riding clipped in and I now prefer the 'solid' clip in of SPD>Time (still running time on my road bike). Pins are pointless - I removed them straight away.
Every way EXCEPT performance in sticky mud, snow and ice. You can pretty much always kick into Time but I've had Shimano jam up with stones/mud/clay/twigs and have to take a tool to it to clear. Also with ice.
No difference for me in clipping in. Crank brothers are meant to be best for that as you can clip in straight down...
Posted : 12/01/2021 6:49 pm
I was about to order a set of Time Speciale 8 recently but ended up not doing so because of just that: reports of bent retaining bars. You don't hear of that at any review, but when asking around actual users, many of them had bars bending. Time seems to be covering this under warranty, but even still, that's not something I'd like to go through, specially at that price point.
Meanwhile, my M8120 XT feel about perfect are are being bashed around mercilessly with no effect
Posted : 12/01/2021 7:17 pm
It's the other way round, if you run them the wrong way it makes them tighter and harder to get out of.
I've always used Times but not a massive fan of the newer style single central spring that has a square profile. They seem to wear quickly, I prefer the old style with two springs and round wire bars, however I think they only come in the bigger caged pedal versions.
Posted : 12/01/2021 7:30 pm
I went through Shimano and Crank Bros before settling on Time Atac. I love them. They engage easily (although not with as firm a click as Shimano) and there is a good amount of float and some lateral placement adjustment, which means I can easily get into the ideal position.
Surprisingly the grip when unclipped is pretty good (Five Ten Kestrel shoes)
Posted : 12/01/2021 7:37 pm
Time pedals are certainly superior in terms of float/feel, and ease of entry/exit. However, they're not as reliable - I went back to Shimano after bushing issues on the Atacs. I've never had issues with the bearings on Shimano pedals, even after years of use.
Posted : 12/01/2021 7:51 pm
i find Time Vague on entry, worse on release and generally not great at staying engaged. Saints are the single best set of SPD type pedals ive used in 30~ years of riding. and i've used them all, including Onzas (if you remember them...)
i have a particularly bad memory of Time pedals in Winter, clipped a wet root under leaves, foot had minimal grip on the pedal but was clipped in. the slip on the root and weight shift caused the vague release to happen and foot slipped out. cue one broken ankle and a 10 mile one footed ride/hop home
i've tried them again with other shoes since and still absolutely hate them.
Shimano i never have clog, the shoes do, but thats the same as any pedal and a quick bang is all it takes to clear. they are ultra reliable and have a great easy entry and positive release point. you always know where you are.
For me its Shimano in the summer, flats in winter
Posted : 12/01/2021 8:17 pm
@zezaskar
Erm... I mentioned it in my review, and even put a picture up to go with it!
Posted : 12/01/2021 9:16 pm
Ooh, it's all pros and cons though isn't it? Pros and cons aplenty! Can't you bastards ever agree on anything?
To add to my list of wants my knees have been creaking for years and last ride I started to get a pretty severe stabbing pain through one knee when putting pressure through the pedals. I'm not expecting a miracle cure but a mate has a set of old mallet DH I can try to see if I get on with them before any outlay. From what I've read they'll probably explode and kill me to death but worth a punt.
Posted : 12/01/2021 9:24 pm
@justinbieber pardon my ignorance then. Because I'm not a subscriber, I can't read the review. I'm curious now, it got the recommended label, even with the bent bar?
Thanks!
Posted : 12/01/2021 10:06 pm
@zezaskar no worries.
Yeah - the pedals are great, and I was able to bend the bar back easily with a pair of pliers so I saw no reason not to recommend them. Bear in mind I ride in the Lakes and am particularly hard on kit, so if you ride in the woods or somewhere less rocky, you shouldn't have an issue with them.
The main thing that I like about them is the entry action - I find it much more natural than Shimano, especially on techy terrain where you have to clip in quickly.
Posted : 12/01/2021 10:16 pm
I've got both across a couple of bikes and for me Time Atac are better. You have to be so much more accurate with SPD's so clipping in in a hurry is trickier, they clog with mud...never happened to me with Times evening the most clayey, claggy mud, and you get more float when clipped in with Times. Unclipping with Times you need to rotate through a wider angle than SPD's but for me that hasn't been an issue. I'd never ride SPD's on my MTB...only on my commuter.
ultimately you'll get used to whatever but for me running both back to back I prefer Time. In fact think I'll ditch the SPD's altogether as the only reason I was running SPD's was for the shoes which I used in the gym spin classes where the spin bikes had SPD's, but now that isn't happening any more think I'll switch over the SPD pedals.
Posted : 13/01/2021 8:00 am
Do Mallets suffer from the same issues with bent bars as the Times? I did read they can unclip if you hit the mechanism on the underside of the pedal hard enough
Posted : 13/01/2021 9:05 am
merlin cycles seems to do Time pedals / cleats at a decent price when they're in stock.
Posted : 13/01/2021 9:12 am
I find shimanos PDM520 and 540 to be perfect in the winter. No need for a cage if paird with a stiff shoe and single release cleats. The cage just adds resistance when unclipping.
Tried other brands but find them harder to clip into but that could be due to being so use to Shimano.
Posted : 13/01/2021 9:24 am
I'm a long time ATAC user due to dodgy knees. I find the different models a bit different.
MXs - Easier to clip into but sometimes hard to tell when its clipped in. It seems a smoother clip than the speciales. If you bash them off rocks the plastic can deform a bit leading to lower spring tension. I find them better than the speciales for for a quick dab and clipping back in.
XCs - Stronger Spring and maybe a little harder to clip into.
Speciales - A little harder to clip into than MXs but obvious when clipped in. Seems a little more of a click/push down to get in. Higher level of retention though.
There are 2 different cleats and 2 different ways of mounting them nowadays. The cheaper pedals tend to come with the 'easy' cleats so plenty of options for playing around.
Posted : 13/01/2021 9:54 am
@davosaurusrex Mallets suffer from the same soft cleat problem that Time do. I did find that my Mallets weren't happy with the Shimano winter boots even with the plastic cleat spacer installed. They got demoted to commuting duties around town as a result.
For clarity the Eggbeaters mentioned up above were early noughties vintage with the cheese bearings!
@daver27 you're describing the symptoms of worn Time cleats. On my commute to work bike these start to go off after about 6 weeks or so. It does take quite a while to be able to easily pull straight out without having to twist the foot when the cleat is truly done.
Posted : 13/01/2021 11:06 am
/blockquote>
Weirdly as a long time ATAC user (I'd ridden pretty much everything from the original design onward) the Speciale were the first ones I really didn't like. Expensive, no appreciable platform over he MX and the bars seemed harder to clip into and to have restricted float (I couldn't get my right leg comfortable). Best looking pedals by far though - especially in the orange...
Posted : 13/01/2021 11:12 am
I switched to Time over 20 years ago, and have them on 4 bikes. Only 1 pair of MTB ones were new, and a recent pair of "link ATAC" with the reflectors (for the road bike used mostly at night). The other 3 pairs were all second-hand and lord knows what sort of use they'd had.
The cleats do wear, they are intended as a bit of a sacrificial part, to maintain the pedals.  I've never had a pedal fail on me, and I weigh c100KG.
I swapped because I found that with SPD's when riding technical terrain I'd unclip inwards as the bike moved beneath me.  This doesn't happen with Time's as they have more float.   Also back in Bristol in the claggey mud, Shimano's clogged up frequently.
I've never bent any of the pedal bars, I'm wondering if this is a combined function of local terrain and the move to ever lower BB's and more suspension travel on bikes (my main MTB is a 100mm travel XC susser from 2006).
I remember "when i were a Lad" that MTB reviews heavily criticised bikes with low BB's due to pedal strikes.  Personally, if you are smacking into rocks with your pedals hard enough to break them, you're not looking where you're going well enough,  and/or picking bad lines (probably because a modern bike is more capable and lets you get away with it).
Posted : 13/01/2021 11:47 am
Well I've got a modern ebike with a very low BB and lots of travel. I usually smack my pedals when climbing when I'm daydreaming so guilty as charged on that!
Posted : 13/01/2021 12:09 pm
@Sandwich,
Mine were literally 2 rides old at that point from memory. Pretty poor when Shimano got it so right, can't honestly remember the last time I replaced Shimano cleats. Or had any issue with them being blocked or unable to release. 6 weeks sounds like they wear out faster than tyres.
I for one will never go back to them. Shame as nice and light. Other than that I really don't like anything about them.
Posted : 13/01/2021 12:18 pm
That was 6 weeks commuting though wasn't it so imagine replacement time wise will be a fair bit longer on an MTB you ride a couple of times a week?
The Times and Crank Bros sound to be very marmite, glad I can borrow a set to try
Posted : 13/01/2021 12:21 pm
@keithb I'd say the bar breakages have more to do with Time changing to forged bars on the newer models than with the lower BBs. I don't really hear of bent bars on the models with the wire bars
Posted : 13/01/2021 12:26 pm
@daver27 I never got on with Shimano for off-road here mainly due to the winter clay. The Time pedals are great in that respect as they work well with the pedal filling stuff we have here.
I've no doubt Shimano will work ok where the local soil doesn't settle in the pedal recess and refuse to move even when 80-odd kilos of mountain-biker applies maximum force. One winter of off-road commuting put me off using Shimano though hey worked well in the dry and dusty conditions (life is too short to change pedals every season).
Posted : 13/01/2021 12:32 pm
Could the Shimano mud performance be shoe related? With AM702 shoes I have zero issues with mud, even when it's frozen. They have this huge channel where the cleat seats, might be related with that
Posted : 13/01/2021 1:28 pm
Put the mallets on, Shimano ME7 shoes with the cleat spacer installed, 15 degrees of float. Feel OK clipping in but unclipping you don't even know you've done it, feels bizarre and makes me wonder if you could do it on the trail and not realise until you hit a feature or whatnot. If you rotate your foot very slowly you can just feel the point where they release but with any speed, nothing. Is this how they are or could this be a symptom of worn cleats? Mate reckons he only used them about 3 times and the pedals certainly look almost new. Might try the 20 degree cleat mounting to move the vague release point a bit further away and make it less likely to happen accidentally. I really couldn't say yet if I'm going to get on with them or not. Support wise they feel no different from the Saints
Posted : 13/01/2021 8:46 pm
That is exactly what I was getting at with the Time pedals. I find Crank Bros the same, Vague vague vague, I cant trust them riding as you are really never sure if you are about to unclip, are unclipped or about to slip a pedal. It's not a nice feeling. Even with new cleats it's (to me at least) a very unnerving feel. Sort of makes a mockery of the amount of float as you can never be sure where you are in relation to an unclipped moment.
Posted : 13/01/2021 9:13 pm
Hmmm, they can't be that bad in practise though surely, given how many of the DH pros run them?
Posted : 13/01/2021 9:29 pm
Not mud zezaskar, premium London clay (the village is called Claydon!) it's an absolute bastard to ride through (Dirty Dans just about coped) and the minute you put a foot down and dab the clay fills the pedal at the next clip in. The next attempt at engagement then becomes quite interesting.
Posted : 13/01/2021 9:40 pm
Very long time user of Time ATAC's due to having shonky knees and therefore need something with a lot of float and don't get on with flats or SPD's. With the exception of one early pair of XC4's where one of the springs snapped (known manufacturing fault on the early batches so it seemed) , I can't fault them.
The brass cleats need to be changed every 18 months-2years as they do wear out but this aside, the pedals seem to be pretty much bombproof and work when caked in mud. In my experience, snow seems to be the only thing that can really clog them up.
Posted : 13/01/2021 9:51 pm
even know you’ve done it, feels bizarre and makes me wonder if you could do it on the trail and not realise until you hit a feature or whatnot.
That’s just how they release, there’s no definite limit as there is with shimano pedals. Time are the same based on experience with some ancient atac pedals. It’s just a spring that gradually opens. There’s a definite adjustment period if you’ve been using shimano pedals as it’s a very different release mechanism. Also ime the pedals don’t get worn, the cleat is a sacrificial part. You can tell when the cleat is worn as it almost rattles in the pedal.
Re accidental release, it’s a non issue although I can appreciate how it may feel that way coming from shimano.
Support - have you checked the shoe is sitting on the pedal body as opposed to hovering above it. You may not need the shim. Also isn’t the ME7 a pretty stiff shoe. There’s a noticeable difference in feel between some Lake xc shoes I have with a carbon sole and my fiveten shoes, mainly in the former I can’t feel the pedal.
Also, I have my pedal pins wound all the way in as I didn’t like the feeling of them disrupting the release. Thought I was just being a fairy but then noticed Brook MacDonald does the same.
When covid naffs off I need to get down your way for a ride.
Posted : 15/01/2021 9:11 am
Love my Atacs wouldn't be without them, the only other pedals I've enjoyed to use as much were Speedplay Frogs, its a shame they seem to have stopped doing them.
The SPDs I tried ended up in the bin, hateful things.
Posted : 15/01/2021 10:42 am
Slight tangent alert, but I can’t fathom out why the bicycle clipless engagement design never migrated back to ski/ snowboard bindings.
The last time I thought about buying a snowboard, I had one look at binding mechanism and freaked! The sheer force with which your legs are clamped in seemed like a recipe for all kinds of injuries.
Posted : 15/01/2021 3:38 pm
I’d say the bar breakages have more to do with Time changing to forged bars on the newer models than with the lower BBs. I don’t really hear of bent bars on the models with the wire bars
Bent bars on tricky very rocky climbs, where pedalling up and the pedal drags across across a rock. Pretty sure I've done two pedals in the same place on the Hondaribbia to San Sebastian coastal path! Not the fault of the pedal really but enough to make me stop.
Bent an axle hitting something with the outside pedal on a fast descent. *&&ing jarred my foot but didn't clip out and or lose any speed which is pretty good sign of how tough they are otherwise
Posted : 15/01/2021 5:09 pm
@Gotama - first ride on them last night, hosed it down all day so was absolutely filthy but fun. Generally liked them, as I thought the release point wasn't an issue for the most part but I did hit one slightly hipped jump not in complete control (as usual) and my right foot came unclipped which was a bit disconcerting. Might have happened on SPDs though, think I will swap the cleats for more float to move the release point further out. Might remove the spacer and see if they will engage but the sole is contacting the pedal so suspect not. Pins wound in. Other than that engagement is good, quite liking the additional float. I don't find them night and day different to SPDs so far to be honest. Got some Giro Chambers to try as well but at the moment they are new and shiny and just for looking at!
And yeah you should come down here, some great trails to ride. Not the variety of Surrey obvs but plenty for a day or two and I never get bored of them. Need to get up there more too, think I've only been half a dozen times since I got the ebike and that was nearly 3 years ago!
Posted : 15/01/2021 8:24 pm
@b33k34 see, that's why I don't get with Time pedals. I can bash SPDs hard enough to make my ankles hurt, up and downhill, and I'm yet to ever even damage a retention mechanism. I doubt you know much people who ever managed to achieve that.
But when talking to Time users, it's more of a "yeah it happens sometimes".
I really like my pedals to be fit and forget
Posted : 16/01/2021 1:28 pm
Yeah, I broke a bar on some cheap XC2s. You could see the bars had been cut/stamped as they had sharp corners, but the warranty replacements (and subsequent XC4s that I've bought) are more rounded and smooth. Not sure of the difference in process (I'd thought forging would be smoother and stronger) but the problem hasn't happened again despite some fairly hard use.
Posted : 16/01/2021 2:25 pm
I bought Time Atacs when building up my Cross bike as they're meant to be better in the mud. Can't say that they're any better than Shimano. If I was buying again I'd have gone with Shimano, mostly because they're cheaper, the cleats are also cheaper, more readily available and last longer than Time ones.
Posted : 16/01/2021 2:43 pm
Thread resurrection here.
Does anyone have experience to compare the Time DH4 with the newer Speciales? Do the DH4 have better resistance to impacts?
Posted : 25/04/2021 5:36 pm
Just getting used to Speciale 8 pedals. The clip in is much more positive (sometimes obstructive almost) and improved by having the cleats the correct way around on the shoe (d'oh, operator error on one pair of NW CF soled off-road shoes).
Posted : 25/04/2021 6:44 pm
 poah
I'm using MX2 pedals cheap, easy to get into and surprisingly light. wouldn't buy the speciale 8 pedals or any of the more expensive MX class (also have MX8s)
Posted : 25/04/2021 9:49 pm
I've moved from MX2s to speciales as over time the plastic on MX2s gets bashed by the springs/arms and the release gets easier and easier. You can often see where bits of plastic have been bashed where it supports the spring. Running 2 different pairs of MXs made it really obvious when one was bashed. I found the MXs easier to clip into but less obvious when clipped in though I think they maybe break in a little and get easier. The speciales have better retention for sure if thats what you want. Price differential is huge though so lots of MX2s for the same money. MX2s are almost as cheap as some replacement cleats!
Posted : 26/04/2021 9:07 am
How are the Speciale holding on pedal strikes? Any issues with bent bars?
Posted : 26/04/2021 10:05 am
So far on my Speciale 8 the bent bars have survived straightening few times. On XC4s I have completely sheared the bar off by hitting pedal on fast descent, luckily I was only 10km from the car
Posted : 26/04/2021 10:44 am
Are you guys using the pins on the Speciale 8?
Posted : 26/04/2021 10:59 am
No issues with bent bars yet (pedals arrived only recently and have done 3 or 4 rides only). Pedal strikes, have you ridden in Suffolk? It will be a rare day if I manage that 🙂
I have the pins fitted but don't use flats normally.
(Watch the thread for me coming back to report on pedal strike having offered up a hostage to fate).
Posted : 26/04/2021 11:23 am
I don’t see the benefits of the pins in this pedal type as I have proper flat pedals and shoes too.
Posted : 26/04/2021 12:12 pm
 Del
I recently got the speciale 8. Much more noticeable clip in/out. Tighter hold on the cleats. What isn't mentioned in any reviews is they've changed the way the spring is retained which I think will eliminate one wear mechanism. I think the pedals I'm replacing are dh4 or similar and as well as the bars wearing the end of the spring has worked at the pedal body and the tension has backed off. TBF  estimate they've done at least 12,000km and I've never needed to do anything to them.
I'm using the pins as additional support rather than for grip.
Posted : 26/04/2021 1:52 pm
What about Time cleats, do they wear any better than the Crank Brothers ones?
Posted : 26/04/2021 11:08 pm
 Del
Difficult to give an objective answer as I moved away from CB many years ago now and I also have a few different sets of riding footwear. I don't see cleat wear as a major expense/faff. I've left cleats on shoes long enough for them to be difficult to remove despite always using grease on them if that's any guide.
Posted : 27/04/2021 8:49 am
