Tight cranks
[Closed] Tight cranks
4 Users
I built a new SolarisMax a couple of months ago & the new 1x Shimano crankset seemed really tight to fit through the external Shimano BB. The BB is from my previous bike & its cranks went through it easily, the BB is still in good nick. On the Solaris it needed some big wallops with a mallet to get the shaft all the way in & also to remove them. I've just started to replace the 1x crankset with a new 2x crankset & it is tight too, the last 12mm or so, so maybe not quite as tight as the first crankset but I've not forced it in fully yet.
Is a tight BB a sign of the BB needing faced maybe?
Thanks.
Posted : 15/09/2021 7:29 pm
Pretty normal to have to whack them through with a mallet ime, think it might even mention it in the manual
Posted : 15/09/2021 7:31 pm
A bit of a tap seems OK, but the first crankset in the Solaris seemed to take excessive wallops than any other I've installed.
Thanks, I'll have a look for a manual.
Posted : 15/09/2021 7:35 pm
I've just taken the cups out & they are tight on the axle still. So nothing to do with the frame.
I've also tried pushing a spare new BB onto the shaft, and it was even tighter. Immediately at the end of the splines there's a step in the shaft diameter making it tight.
Mallet time it is then.
Posted : 15/09/2021 8:12 pm
Do you still have the old cranks, just to see if they offer up as they did when the BB was in your old frame? I must say, when I read your OP the first thing that sprang to mind was BB squareness.
Posted : 15/09/2021 9:08 pm
No, I sold the old crankset & the old frame. I've only got the old BB, plus two new cranksets & a new BB also. The old 3x crankset was pretty old though, so maybe it had gotten slacker through the years.
Posted : 15/09/2021 9:12 pm
I distorted a centre tube assembling a BB and it caused a similar problem.
Posted : 15/09/2021 10:16 pm
The centre tube isn't distorted. I've booked the frame in to get the BB faced next week.
Posted : 16/09/2021 10:28 am
