Thule Racks and Car...
[Closed] Thule Racks and Carbon frames....
12 Users
... is it possible to overdo the tightness of the "grabber" on the downtube and damage the frame?
Posted : 13/12/2012 12:19 pm
I think officially they recommend not clamping or even holding a carbon frame on a bike rack using the frame tubes.
When I've had to put carbon frames on the roof, I've only done the gripper up just enough to hold it without movement but no tighter. I also drive a little more cautiously.
Posted : 13/12/2012 12:29 pm
bit of helicopter tape around the grab point maybe to stop scuffing?
Posted : 13/12/2012 12:30 pm
 br
[i]... is it possible to overdo the tightness of the "grabber" on the downtube and damage the frame? [/i]
Of course. Better to use some pipe insulation, that way you've 'slack'.
Posted : 13/12/2012 12:31 pm
I was going to use some innner tube.
Hmm, sounds like I'd be better of removing the wheels and sticking the frame on the back seat...
Posted : 13/12/2012 1:11 pm
Depends on the frame I suppose- On One say the C456 is fine with it, and that seems legit to me, it's tough as old boots... Though the finish won't stand for it.
ChrisL's Mojo's often been on his Thule rack and seems none the worse. Sturdy frames. But then not all carbon frames are like that, I'd be more wary of a superlight XC frame.
Northwind - its a Bianchi road bike...
Posted : 13/12/2012 1:12 pm
Road bikes have to use a fork mount carrier and have a separate carrier for the front wheel.
It's the law.
Posted : 13/12/2012 1:14 pm
My carbon mojo HD goes on my thule rack all the time, I havent taken any special precautions, just clamp it up the same as I did on my old alluminium bike.
Posted : 13/12/2012 1:15 pm
Its the back seat then, I need to carry it Sunday and no time / money for a fork mounted rack.
*Thinks* Although I may have one tucked in the garage somewhere....
Posted : 13/12/2012 1:16 pm
I think I'd go the upside down route with one of those saddle clamps and bar clamps on a carbon road bike.
Posted : 13/12/2012 1:41 pm
I think I'll do thism with some lagging or inner tube to protect the finish - its only 1 30 minute trip on Sunday. If the worst happens, I'll have all the bits to build onto a Ribble frame.... :-/
Posted : 13/12/2012 7:39 pm
It's winter time, your carbon road bike must remain tucked up in the house 😀
Posted : 13/12/2012 7:46 pm
ive regularly had carbon mountain bikes in mine, and they have been fine despite, in one case, specific advice from the manufacturer not to do it. worth some helitape so the finish isn't rubbed off though.
Posted : 13/12/2012 7:59 pm
Well over the course of the day I've been researching the effects of damage on carbon, including vibration from roof racks and stone chips from the road.
I've changed my mind, its wheels off and in the backseat!
Posted : 14/12/2012 5:25 pm
Stone chips from the road?? Is your car going to be churning up the ground that much that stones will be flying up over your roof?? 😉
Posted : 14/12/2012 6:29 pm
Other people's stone chips.....
Posted : 14/12/2012 6:35 pm
If you can afford a bianchi road bike in carbon, you can afford an £89 Thule fork mounted rack ;-)... They are much more stable too
Posted : 14/12/2012 7:42 pm
Are carbon forks gong to be strong enough for that kind of thing?
Posted : 14/12/2012 7:49 pm
Yep, no different to 60mph down a bumpy mountain A road.
They are designed for those forces, the frame not so much.
Posted : 16/12/2012 9:05 pm
hmm, not sure why i wouldn't use one. If it's good enough for cycling team cars then why not use the same system at home:
Posted : 16/12/2012 9:19 pm
Free bikes, I'm sure they don't care about anything others than getting the spare bikes off quickly as possible
Posted : 31/01/2013 9:29 pm
