the one that connects the light to the battery and screws together ,what they called and any idea where i can get a couple
As ever, e(vil)bay:
The magic phrase seems to be: "5.5mm x 2.1mm Waterproof DC Connector"
Cheaper if you can wait for shipping from Hongkong.
thanks
Some of mine are 5.5mm x 2.5mm centre - best check if you are only replacing 'one end'.
I just replaced one from a solarstorm that was 2.1mm. Curiously the 2.1mm plug looks bigger than the 2.5mm one, I think because the plug wall is thicker even though the inside diameter is smaller.
i bought a couple of the chinese lights with a usb plug to connect to a usb battery box but the usb connectoer is pants so going to change to waterproof one
