Thomson Stem 3mm bo...
[Closed] Thomson Stem 3mm bolt stuck fast.
9 Users
After twisting all my 3mm Allen keys and going through a can of WD-40 I let it rest.
Big respect to Thomson, the bolts haven't rounded, but I still want it off those forks.
Any tips.
Posted : 31/07/2016 11:18 am
3mm??
Impact driver/hammer setting on cordless drill.
Or flames.
Posted : 31/07/2016 11:25 am
 Rich
Tighten the other slightly to give it some slack.
Posted : 31/07/2016 12:04 pm
What Rich said.
Posted : 31/07/2016 12:55 pm
 jonk
Hammer torx into it then remove - had to do this a few times despite using the correct torque to tighten them.
Posted : 31/07/2016 1:01 pm
Those 3mm bolts are pretty stupid imho
Posted : 31/07/2016 3:04 pm
The 3mm bolts are Thomsons defence against users cracking face plates
Posted : 31/07/2016 3:08 pm
Can you remove the other 3 bolts and then try rotating the faceplate?
Posted : 31/07/2016 3:18 pm
 Del
Not sure why you'd want to hammer a torx bit in to a heard that's not rounded?
Impact driver and/or a liberal dousing with boiling water would be my suggestion.
Posted : 31/07/2016 3:35 pm
