Thomson Elite Seatp...
[Closed] Thomson Elite Seatpost - Can I cut it?
8 Users
I bought the long one second hand after a cheapy failed on me, but it's about 3" too long and won't go far enough in to the frame (on one inbred) :-/
Obviously I need to leave enough inside the frame to keep it safe, but If I make sure the length of the post in the frame is greater than the MAX amount marked on the post that should be fine I guess?
I also understand the issues with trying to cut a tube without distorting it, but that's a challenge I am prepared to take.....
Posted : 07/06/2016 5:59 pm
No issues, just use a nice new fine hacksaw blade and a file to finish it off
Posted : 07/06/2016 6:02 pm
Can I cut it?
Yes you can!
Posted : 07/06/2016 6:05 pm
You can?
Posted : 07/06/2016 6:11 pm
 br
I've always found the a pipe cutter does a decent job, and comes with a deburrer.
Posted : 07/06/2016 6:12 pm
just feed it into the hole in the top of your blender until it's about the right length 😀
on a more serious note, the main issue is clamping it if using a hacksaw - ie be very careful and I would rest it on the just open jaws of a black and decker workmate rather than clamping it. Or use a pipe cutter, adjusting a tiny amount each time.
Also remember you min insertion mark is now X higher with X being the amount you chopped off.
Posted : 07/06/2016 6:13 pm
Pipecutter! Why didn't I think of that? Heads to garage....
Posted : 07/06/2016 6:23 pm
Pipe cutter will deform the tube, finish the outside edge with a file.
Posted : 07/06/2016 6:25 pm
can I cut it?
Yes you can!
That was my first thought too 🙂
Posted : 07/06/2016 7:08 pm
I just hacked through mine with a jigsaw whilst holding it. Looked a right mess but you never see the bottom bit anyway.
Posted : 07/06/2016 7:24 pm
