This weeks headset ...
[Closed] This weeks headset question.
4 Users
I bought an angle headset T7-2 EC44/ZS56 100-110mm Taper Steerer from Superstar which fits .
I now need a non angled version. Looking through Superstar's headsets I can't see anything that tallies with those numbers even ones out of stock.
Point me in a right direction please.
Posted : 20/06/2021 10:00 pm
 Yak
Edit - all wrong before- misread it!
Any EC44/ZS56 will do. Hope/ FSA etc if superstar are out of stock. Top cup can, and is more available as a ZS44 as the external cup isn't necessary. You will probably add a 10mm spacer under your stem to make up the height loss.
Posted : 20/06/2021 10:18 pm
So a normal headset then if I'm understanding you, a zs44 upper will be the answer and a reducer crown race if its a straight steerer.
Or do you want a reach adjust headset.
Posted : 20/06/2021 10:33 pm
 Yak
Yeah, I misunderstood it first.
ZS44/ZS56 is what you want.
Posted : 20/06/2021 10:38 pm
Your angleset only has an external top cup to fit the angle change, any steerer (tapered or straight) will have the same diameter at the top 1 1/8" and will work with a zero stack 44mm cup. So as above, any ZS headset 44/56 will work
Posted : 21/06/2021 9:00 am
