Thin freehub shims ...
[Closed] Thin freehub shims to get indexing right between turbo trainer and wheel?
6 Users
Got an Elite Suito T (it was cheap-ish and available), the indexing is a bit off compared to my wheel, any thin approx 0.2 mm shims available that fits shimano 11 spd freehubs?
Posted : 15/02/2021 4:49 pm
Shimano HT2 BB shims.
Posted : 15/02/2021 4:54 pm
Hmm I measured the distance from the frame to the smallest sprocket on the turbo on with the wheel installed, the sprocket on the suito cassette (R5800 11-28) is exactly 1 mm closer to the frame than on the bike (R7000 11-32) - so I would have to shim the bike cassette to get closer which I don't really like as it degrades the chainline in the smallest sprocket..
Or could it be the cassettes that are different.. lengths?
Posted : 15/02/2021 5:26 pm
A dedicated turbo bike is the only real solution 😃.
Posted : 15/02/2021 6:18 pm
The cassettes are the same length about 40 mm not including the lockrings, but the length from the seat of the freehub body to axle hole was 1 mm shorter on the Suito, so I need to find a 16 mm ID 22 MM OD 1 mm thick shim that extends the drive side
Posted : 15/02/2021 6:20 pm
If you know how much it is out by then readjusting the shifting each time you change wheel/trainer should be childs play.
Posted : 15/02/2021 6:21 pm
12mm or qr? You could shim the drive side by 1mm rather than the cassette.
Posted : 15/02/2021 6:27 pm
12 mm, yes going to shim the axle on the trainer (there's a thru axle adapter that screws into it, it can be shimmed w a 1 mm spacer) - something like this
fd
Posted : 15/02/2021 7:06 pm
 mc
If you know the exact dimensions, I can machine you one.
I need something to do while my CNC lathe munches it's way through a few lengths of bar this week.
Posted : 15/02/2021 7:13 pm
Appreciate it! Already ordered this one, plus im in Germany..
Posted : 15/02/2021 7:15 pm
I’ve had the same/ similar problem with my elite zumo although my sram 11 spd cassette wouldn’t cinch together without a spacer but with the spacer indexing was out! I gave up and bought some mudguards!
Posted : 16/02/2021 9:26 am
