Thick question abou...
[Closed] Thick question about Superstar torque wrench
7 Users
The dial numbers read up to 1.5 in two directions. How do you set it to say, 4nm? I don't understand the scale of numbers on the dial.
Posted : 27/12/2014 11:08 pm
Not got the specific one you're on about but usually the shaft will be demarcated in increments of 2, so 4 would be 4 on the shaft and zero on the dial, 5 would be be four on the shaft and screw 1.5 forward (or six on the shaft and 0.5 back)
Posted : 27/12/2014 11:12 pm
I have the Superstar one. Every 1Nm clockwise on the round base knob increases the torque setting, as shown in the upper window, by 1Nm, so it will be 4 of these to get it to 4Nm
Posted : 28/12/2014 12:39 am
Ah, gotcha. Even on the weakest setting, there's no audible click or snap from it though when tightening bolts.
Posted : 28/12/2014 11:18 am
Doesn't the head just flop to the side?
Posted : 28/12/2014 11:21 am
What jamie said, put it at a low torque, like 2Nm and turn slowly on a stem bolt or similar and watch for the head handle flopping.
Posted : 28/12/2014 11:35 am
The 'flop' is much easier to feel/see if you tighten the bolts slowly.
Posted : 28/12/2014 11:52 am
 CHB
I made the same mistake...the head just flops at the torque limit. There is no click.
Posted : 28/12/2014 12:27 pm
Yep checked all my bolts last night, all overtight! Great bit of kit, will save some expensive kit
Posted : 28/12/2014 1:55 pm
