There must be anoth...
[Closed] There must be another way? (or Gary gets it)
5 Users
I've got a Gary Fisher Hifi pro 2008 frame, its eating eyelet bushings on one of the shock mounts, about one a month, so i'm reckoning the mounting hardware is a little worn(the bushing runs directly on the bolt in the photo). There are also a couple of (ceramic?) spacer/bushing things that i doubt are helping as they'll be 2 yrs old now.
Anyway, I've bee quoted £95 for a replacement set of the bits in the photo below, which i cannot afford, so either another way needs to be found or ill be looking for an on-one 456 very soon.
Anyone have any ideas?
The mounting :
Taken apart:
Thanks a lot
Posted : 23/02/2011 9:17 pm
Get a few more quotes, that seems a bit expensive to me.
Try a google search on them.
Posted : 23/02/2011 9:22 pm
Is the frame out of alignment? I don't believe it should be eating bushes that quickly.
Posted : 23/02/2011 9:24 pm
I'd go for that as the cause, back to the LBS
Posted : 23/02/2011 9:27 pm
don't trek offer lifetime warranty on bearings?
Posted : 23/02/2011 9:28 pm
I think it's the bolt that the bushing runs on is worn, when i got the frame about 6 months ago it had play in it so i replaced the bushing, maybe it was used for a while with play? wearing the bolt? It's acting as a top hat spacer which you'd usually replace every once in a while. I don't think the frame is out of alignment, not had any big crashes on it.
Posted : 23/02/2011 9:30 pm
I asked trek about the part, part no 292904. They didn't let me order it from them as im only a consumer...
Taking it back to the lbs isn't really an option as i bought the frame second hand.
Posted : 23/02/2011 9:32 pm
ah, 2nd hand so no warranty, sorry!
is there an easy way to check frame alignment? seems like a hardtail is becoming more and more likely...
Posted : 23/02/2011 9:47 pm
