You know what I mean? Those little bit sof split plastic that go round a brake hose then push into the stop in the frame to hold it in place?
Know where I can get some or what they are called so I can google?
Ferrules or cable end caps
http://www.parker-international.co.uk/5118/Shimano-SP40-41-Outer-Cable-Casing-Caps.html
I know what you mean but I can never find them so I use zip ties.
No not them. I know they are ferrules.
What I mean is a plastic sleeve that goes round a (hydraulic) brake hose to make it a bit fatter so that it fits in the stop (usually the stops next to the gear cable ones on the top tube) on a frame.
They usually have a split down one side so you can get them round the hose and a small lip at one end to stop them sliding all the way through the stop.
I had 'em on a Cannondale too and I need a couple for my nephews Kona....
I could bodge with insulation tape or just cable tie them but I reckon they must be available and surely only pence?
Jagwire do them
I did buy some but I can't remember where from
http://www.jagwireusa.com/index.php/products/mountain/484
Do you mean these?
MPart: Top Tube Cable Guide Set
http://www.wiggle.co.uk/p/cycle/7/MPart_Top_Tube_Cable_Guide_Set/5300005193/
MP if you find any let us know as i reckon i'm going to need some on my frame i just bought
Uplink is right.
Google / eBay is not helping me find any to buy though.....
Jagwire part number: DCA072
I only need a couple of the bl**dy things.
WooHoo. I have a couple of those sat on the desk in front of me, looking for a good home.
Must be worth more than what RBS is worth!!! Who wants them. First come, first serve. Mail me.
Nobody want them? Oh well, back in the parts box!
Me!YGM!
Instead as per someone's suggestion ages ago
http://www.singletrackworld.com/forum/topic/how-do-you-secure-the-gear-cable-in-the-guide-hoops
I used some carefully squirted silicone seal into the guides, poked a small hole in it, let it set and then routed the cable through the (tight fit) hole. Works well to stop slap/rattle but it does slip through.
Noahs Ark have the 'dale ones in the workshop which they will sell. Not online though. Give them a call.
found some!!!!
[url= http://www.cannondale-parts.de/epages/61764971.sf/en_US/?ViewAction=View&ObjectID=1203098 ]here[/url]
