I once used a van as a headset press.
It was my first bike build, a 456 Summer Season, and I had no specialist tools. But I did have a Mercedes Vito with a big towbar beam at the back and a trolley jack. I jacked up the rear axle, put a block of wood on the ground, the headtube vertically on the wood block, the headset cup on the tube and another block of wood under the towbar beam. Then I very carefully let down the jack. The cup went in slightly out of alignment but quickly stopped arguing with two tons of van and dropped into position. The other cup went in even more easily as the first cup kept the tube more upright.
What wrong tool for the job are you prepared to 'fess up to?
Last week i installed a headset with a lump of wood and a hammer. Went in perfectly straight, van and trolly jack seems like a lot of fuss.
I once used a rear QR to open a locked door when I had locked my keys inside.
Was impressed with myself at the time, then worried how easy it was for an amateur to break in to my house.....
i once used a lenth of nylon rope to replace the valve stem oil seals on a seirra cvh work that one out
mav12 - Member
i once used a lenth of nylon rope to replace the valve stem oil seals on a seirra cvh work that one outPosted 2 minutes ago # Report-Post
who hasnt
saves taking the head off dunnit.
anything that isn't a hammer is the wrong tool for the job.
Waste pipe for knocking headset races on and supporting hubs on when drifting out the bearings.
Wedge a spd bearing collar remover in a door if you don't have a spanner big enough (open door insert spd tool into gap between hinge/door frame try to close door, twist pedal) *may damage paint/wood work*
IME an old straight handle bar (cheap/heavy duty don't use carbon fibre xc racer bars) is easier to drift out headset cups than a screwdriver or other narrow drift.
Mole grips! wrong tool for every job.
good quality tapered molegrips are grand for removing flare nuts - where flarenut spanners have failed....
fork truck to install a headset.
Michael Gove for Dept. of Education.
APF
i used a drainpipe wall clamp as a piston ring compressor on an fz750 as it was exactly the right size.
cut up icecream tub and a jubalee clip as a piston ring compressor on a rotax 122
My Dad once compressed a transit coil spring in a doorway, with a bottle jack. As it compressed he bound the coils together with steel wire. Once in place he snipped the wire & the spring...sprang. (Somewhat noisily).
But those are the correct tools for the job.
10ft length of scaffold pole to remove a Rohloff sprocket
Not a tool, but the wrong bolts for the job - bought some new SHIMANO disc rotors, put them on my new wheels.
Wanted to transfer the old front wheel to another bike - so used the bolts that came with the Shimano rotors.
Silly me for not realising these bolts were TOO LONG to be used as disc rotor bolts and one of them split the flange on the CROSSMAX hub.
Had those wheels for 7 years. 7 years of riding and a stupid bloody bolt fudges it up 🙁
Only positive is I didn't use them on the new wheels.
