The incredible disa...
[Closed] The incredible disappearing pawl spring
8 Users
Decided to check freehub as I know the mavic ones need a bit of lube now & again.
Did it in the living room (watching lego masters Australia with kids)
And one of the springs is just gone, found the pawl but spring....
Now I've gotta pay £15 for a teeny spring
Anyone know if hope bulb ones fit?
SPRING DIMENSIONS: 5MM LONG (1.85MM COMPRESSED), 3.25 OUTER DIAMETER, .35MM WIRE
Posted : 06/02/2022 9:55 pm
Under the sofa.
Posted : 06/02/2022 10:05 pm
Like kayak23 said, under the sofa. More likely it’s bounced under the sofa, then bounced 15 more times & ended up under the fridge in the utility.
It’s called ‘fridge suck’. Like chain suck only more annoying.
Posted : 06/02/2022 10:08 pm
Chop a bit of spring out of a clicky pen
Posted : 06/02/2022 10:17 pm
I've got some Hope ones here if you want. PM me.
Posted : 06/02/2022 11:07 pm
sourcing map Compressed Spring,0.12 Inch OD, 0.01 Inch Wire Size, 0.08 Inch Compressed Length, 0.2 Inch Free Length,2.6N Load Capacity,Gray,10pcs https://www.amazon.co.uk/dp/B08LD1K54K/ref=cm_sw_r_cp_api_glt_i_C1AF99CAHM1BPMYCZVXW?_encoding=UTF8&psc=1
ask me how I know this…
Posted : 06/02/2022 11:08 pm
Thanks for the offer ambrose
Jambo you're amazing!
Posted : 06/02/2022 11:19 pm
Are they magnetic? I have a couple of magnetic 'sticks' in the shed for finding all of the things that fly around in there.
Posted : 06/02/2022 11:26 pm
Yup I've got the big magnet out, no joy
Posted : 06/02/2022 11:28 pm
Have you got a tap and die set? I found a rear suspension spacer that I lost a couple of bikes ago inside the case. I spent hours searching the shed for it at the time... it'll be the first place I look for anything that goes missing from now on 😛
Posted : 06/02/2022 11:39 pm
Found it!
On the bookshelf about 2metres from where I was sitting
Posted : 07/02/2022 12:20 am
Bravo!
Nothing adds value to an item more than finding it again after it's been lost.
Posted : 07/02/2022 1:19 am
Found it!
I bet that was the last place you looked as well?
Typical...
Posted : 07/02/2022 7:54 am
Found it!
Was it in correct ISBN order?
Posted : 08/02/2022 5:46 pm
