The different types...
[Closed] The different types of road bike
6 Users
Morning all knowing STW.
Racing, Audaxing, TT, sportive etc … can STW please explain the different types of dark side bikes.
Especially the difference between TT/racing bikes... as I’m thinking of giving triathlon a go.
Thanks
Posted : 15/02/2011 10:19 am
TT = low aero position (esp bars) = highest straight line speed, single use, handling compromised
RR = drop bars, tight clearances, lower position than sportive bike
Sportive = drop bars, more upright position than RR, possibly lower gearing (compact chainset)
Audax = like sportive only room for mudguards, typically a 'winter training bike'
All clear?? 🙂
Posted : 15/02/2011 10:24 am
That's about right.
Tri'ers use slightly different bikes with steep seat tubes and small wheels. I think the rationale is that they need this to get into an aero profile, their ability to get into a flat-back position being comprimised by the body's adapation to the other dsiciplines.
FWIW the difference in your time for bike section of a tri will be affected very little if you are riding a reasonably light road bike with decent tyres.
Posted : 15/02/2011 10:30 am
Did my first tri on an MTB with slicks on 🙂
You could always stick a set of aero bars on a road-bike to give you a more aero position too.
TT bikes are not suitable for training on either - you'd need a RR bike or similar to train on so if you're looking for one bike start with a RR.
Posted : 15/02/2011 10:36 am
The Tri bikes we sell are pretty much all 700c wheels apart from the 48cm frames have to run 650 wheels purely because 700 won't fit.
Posted : 15/02/2011 10:37 am
 kcr
Good road bike summary in the first post. You could add "Touring" for completeness - generally a bit beefier than your Audax or fast touring bike, with a triple chainset and all the fittings for racks, mudguards, etc.
If you are buying to race, and have no road experience, a low to mid-range RR bike is definitely your best bet for starting out. Suitable for general training and bunch riding if you join a club, but adequate for some tri-racing with the addition of clip-on aero bars. A dedicated TT bike will be faster, but less flexible, and the position and handling are more challenging if you are new to road cycling.
However, the tip about using a slicked-up MTB with tri-bars for starters is a good one. Andy Wilkinson (former national champ and multiple TT record holder) has famously won several time trials on a converted hybrid.
Posted : 15/02/2011 11:18 am
I'd disagree there, even some clip ons can make a reasonable difference in a tri. I did a rolling 16 mile bike leg in a tri on my Madone and lost a significant amount of time to folk on TT bikes who I'd normally trounce. A flat bike leg would make TT bikes even more beneficial.
Bear in mind tri/TT bikes are not allowed in road races, and are generally not comfortable for long rides, as well as having twitchier steering making them a bit of a handful in traffic.
If you want a bike purely to race tri's on then a proper tri bike will be well worth it. If you want more versatility then a conventional road bike (with geometry you find comfortable) will be a better bet, perhaps with some decent clip ons for triathlon use.
Posted : 15/02/2011 1:26 pm
