evening all
i have had a Tf service kit delivered by TF for my pikes.
I have stripped the fork no worries it had no oil in the lower legs at all so think it was well over due.
Know i am coming to re fit i am stuck. In the fork there was one wiper and a foam ring. Tf have supplied a wiper and a oil seal and a foam ring thinner than the original.
Do i put the foam ring in then the oil seal then the wiper?
Also is 16CC right for a solo air pike?
wiper, foam, oil seal
it's a much better seal than the wiper/thick foam one that some have. Personally I don't bother with the foam ring on these though. Just grease on the seals, and oil in the lowers.
cool thanks any hints on how to get the seals in they are tight as chuff
i use a hairdryer to heat 'em up, then use a thick screwdriver wrapped in black electrical tape
is that to put the new ones in or the old ones out
