Testing your memory...
[Closed] Testing your memory. Thin Goodridge bradied hoses.
5 Users
Probably one more for the older riders or shop staff. A while back (around 2007 maybe) Goodridge changed for a short period to thinner hoses. They were pulled quite quickly though as they weren't as easy to fit (iirc). What I can't remember is if the fittings were the same between thin hose and thick hose, can anyone else?
Why does it matter? Because I've a set of the thin version that I've moved to a new frame that needs longer hoses.
Posted : 15/09/2015 12:03 pm
Just ring them directly.
I use them for custom lines on the race bikes and they are very, very good.
sales@goodridge.net
Natalie.Rossini@goodridge.net
Posted : 15/09/2015 12:09 pm
Cool, thanks for those.
Posted : 15/09/2015 12:14 pm
Fittings where the same you had to trim off the clear coating on the thicker hose to get them in the fittings.
Posted : 15/09/2015 12:41 pm
What Baznaz said.
It took the fun out of trimming it away with a stanley knife. what could possibly go wrong!
Posted : 15/09/2015 12:44 pm
😀 brilliant, thanks. Makes it a bit easier. Shame the thin hose was stop as its much more flexible than the thicker version.
Posted : 15/09/2015 12:55 pm
You could get the thick hose to fit by cutting the clear coat, but they did have different fittings. From hope silver mono era - they had 5mm hose with 4mm being the new standard.
I have both the thick and thin alloy fittings (or I am 90% sure I still have them)
Posted : 15/09/2015 2:25 pm
