Tendency to lean th...
[Closed] Tendency to lean the bike to one side slightly while pedaling?
12 Users
Bit of a weird one here..
I've noticed that while riding I tend to lean the bike ever so slightly to the left while riding in a straight line. I've done it for a least a year (can't really remember past that) and it's starting to frustrate me a little. On longer rides this causes pain in my right wrist and I find that going down steep chutes and ruts the bike feels like it wants to slide out to the left.
Some notes I've found so far:
-I tend to lean the bike to the left in all cases, whether I'm standing, seating, pedaling, freewheeling etc..
-It happens on flats and clipped in.
-There's no mechanical issues I can spot that could cause it, ala frame alignment or stem alignment. Bike's a Mega AM.
-I can make the bike ride straight if I really try, but this makes my right shoulder/arm ache as it feels like I'm pushing down on the bars to stop the bike from leaning.
I'm wondering if there's a biomechanical issue somewhere, like a leg slightly longer than the other or a hip higher than the other? I don't think flexibility is the issue as I stretch and use foam rollers daily.
On an aside, any recommendations for a bike fit in cardiff with experience in mountain bikes? I'm not sure how much I'd get out of a road-style bike fit given I prefer flats and otherwise i'm happy with the cockpit, I'd rather a fit that looks to solve this problem.
Posted : 22/01/2016 8:14 pm
Which side does Sir dress to?
Posted : 22/01/2016 8:28 pm
Perchpanther could be right - try it with your schlong on the other side
Posted : 22/01/2016 8:35 pm
You can try shortening the bars from the left side in .5cm increments. Or just move the grip, but that wouldn't be fun.
Posted : 22/01/2016 8:38 pm
Maybe get an assessment from a physiotherapist or osteopath?
Posted : 23/01/2016 6:08 am
Has anyone verified that the bike is leaning over it is it just from your viewpoint as a rider?
Posted : 23/01/2016 6:27 am
If you look down at your bike and it looks tilted, it could just be your dominant eye playing tricks with you. Like wot spooky is getting at, I imagine.
Posted : 23/01/2016 6:40 am
Ride on a dry road for a while with dirty tyres, you might see a clean band of tread develop to one side of the tyre centre line and confirm the lean
Posted : 23/01/2016 7:14 am
Wouldnt worry about it until you start quoting trotski
Posted : 23/01/2016 8:14 am
I know my right arm is marginally longer the left so have to have the bars at a tiny angle (0.5deg) to make it feel right and not get shoulder ache on longer rides. It's such a small difference that I can't feel it if bars are straight or slightly to the left when on shorter rides, but can when they are to the right.
Posted : 23/01/2016 8:28 am
 DanW
Sounds very normal. Everyone will be a little lop sided to a certain extent as we aren't made symmetrical but bicycles are 😀
Usually something like this comes a slight imbalance in the less superficial (deep) muscles around the hips which are very hard to target with normal stretches and certainly way out of range of a foam roller. If you don't have a solid base near the saddle your arms will have to work harder to stabilise I guess. Could well be an arm problem but usually these thing come from a root problem away from the source of the pain.
I would look at getting your body checked over by a bike friendly physio rather than look for compensation on the bike first. If you can combine it with a "fit" then great but I'd look to yourself first as I say.
[url= http://www.spirehealthcare.com/cardiff/cardiff-orthopaedic-centre-of-excellence/pro-motion-dynamics/ ]Maybe somewhere like this but I have no first hand experience myself[/url]
Posted : 23/01/2016 10:46 am
I get the same sensation sometimes and when you start noticing it it is really annoying... I'm not sure what causes it but it could be to do with a leg length discrepancy (not uncommon I understand). I know that slightly wrong seat height can exacerbate the feeling and I think it's to do with how you sit on the bike to accommodate for the difference in leg length. I understand that having 'tighter' muscles/tendons on one leg can also give a similar feeling. I know something is up with me because I always place one foot further forward on the left pedal to compensate for the difference. I try and ignore it all and just ride though. Easier to ignore off road than on.
Other things I have found include worn suspension forks which can sag to one side
Posted : 23/01/2016 11:13 am
 Euro
As long as you're not just going round in circles, you should practice riding no handed. A lot.
Posted : 23/01/2016 3:09 pm
