Tell me about tubel...
[Closed] Tell me about tubeless
10 Users
So I want a set of pro 3's with stans rims.
Do I have to use tubeless tyres or can I use any tyres and sealant?
Do I have to use a rim strip on tubeless ready tyres?
If i rip a tyre can I just I throw a tube in with a tyre patch?
Whats good and whats bad.
cheers
Posted : 07/04/2011 7:56 pm
Depends. Some tyres are 'tubeless ready'; some will work; some won't. I believe there may be an issue with seating true UST tyres on Stan's rims but I am prepared to be corrected.
Not with Stan's rims - use rim tape and a valve. If you are converting a non-UST rim from another manufacturer, you will need a rim strip (or a ghettoed BMX tube).
Yes.
There is more info than you could possibly ever need in the Notubes.com help centre.
Andy
Posted : 07/04/2011 8:04 pm
not so, i run stans 25 mm tape & valve on dt5.1 with some old spesh non ust adrenalines and sealant. Works so well they lose less air than the ust rr & nn i had on before.
Posted : 07/04/2011 8:12 pm
Cheers Andy
will check on stans site
Just got some Stans Flow on PRO2's, using Stans tape/Valves/sealant along with Wire Bead Maxxis High Rollers......work a treat!
Posted : 07/04/2011 8:22 pm
Maxxis seems to be really good for UST I use them all the time, they just fit so easy no faffing
Posted : 08/04/2011 12:17 am
That is interesting; as I understand it, it's also pretty much how Roval tubeless rims work. I thought the rim strip was meant to be essential to wedge the tyre bead against the rim, though?
Andy
Posted : 08/04/2011 10:41 am
No, it can help but it's not essential. Weight weenies just use tape on the spoke holes. I think with some rims it's more important than others.
Posted : 08/04/2011 10:46 am
You may also find you need a compressor and motorcycle style tyre leavers.
Posted : 08/04/2011 10:47 am
Tubeless is still a bit 'try and see' some combinations work fine with no rim strip, others don't. It's well worth the effort though IMO.
Posted : 08/04/2011 10:48 am
Nobby Nic's on Stan's crest tight to fit but inflate with a hand pump.
Maxxis High Roller (Non UST) Easy Fit, soapy water and compressor to seat at first
Posted : 08/04/2011 11:02 am
All Maxxis variations that I've tried on Flows (with yellow tape) have gone up easily with just a track pump. So far that's:
Minnion 2.35 ST single ply
ADvantage 2.? UST
High Roller 2.35 60A single ply
Larsen TT 2.0 single ply
plus one non-Maxxis so far...Halo Choirmaster UST
Thouroughly recommend tubeless.
Only issue has been from ripping the sidewall a little too easily on the rear tyre when running single ply. Not a problem - just fit a tube. Have since gone to UST on the rear and standard single ply front and am now very happy.
Main advantage for me as a clumbsy rider is pinchflat avoidance. My record prior to tubeless was THREE pinchflats in a single descent of Garburn (at about 40 psi!!!).
Have now been able to drop to 30-35 psi tubeless, definately ride harder than I did previously and remain pinchflat free. The best change I ever made.
Posted : 08/04/2011 11:33 am
