Have had an answer elsewhere that says I’ve got problems but I’m always up for a better second opinion.
On one front 135 rds hub in a 150 fds post Mount bluto fork.
Can get spacers to cover the 150 bit but will the disc be too close to the fork or too far away?
On some cheap Chinese 135 sus forks I had to space the disc across to the calliper.
Someone give me some good news. I really don’t want to buy a new hub.
I believe you want one of these
http://carverbikes.com/parts/brakes/5-mm-rotor-adapter-kit/
Might not work with your spacer 0lan though. Pushing the caliper inboard by 12.5mm seems a bit dodgy.
Personally, I'd go with a new hub.
Google suggests the disc will be 4.8mm too far away (RDS spacing puts this disc onboard of FDS)
