Teflon Grease good ...
[Closed] Teflon Grease good for hubs/bearings or better with REAL grease?
4 Users
So I'm rebuilding a Hope XC hub and I started wondering about my choice of grease (for pawls, bearings, etc)
I normally use Finish Line Teflon grease:
But thinking about it, Teflon-based dry lube doesn't seem to last very long on my chain, especially if it rains.
So does this mean Teflon grease also has a short lifespan?
Would I be better off using a [i]real[/i] (oil-based) grease to maximise the service interval? Or am I comparing apples and coconuts?
What sayeth the Mind?
Posted : 29/06/2013 9:04 am
I use CV grease for bearings, and copper grease for anti-seize applications. Each are about £5 for 500g and will last a lifetime on a MTB.
I dont buy into all this over priced MTB specific stuff.
Posted : 29/06/2013 12:19 pm
Isn't the idea of bike-specific stuff that it can (and should) be a fair bit lighter than grease used on cars etc cos it isn't subject to the same forces and has to work at a much lower temperature?
A 100g tub of Teflon grease is only £9 and I've had the same one for over a decade, so yeah it is more pricey but hardly breaks the bank!
Posted : 29/06/2013 2:59 pm
my experiance of the grease you posted above is that it pretty much evaporates seconds after fitting 😉
when i need low friction (tt and road race wheels) ill oil the bearings .... on my MTB im happy to live with a bit of friction in exchange for a life span of more than 10 minutes
* edit - just take a look at the grease that comes stock in shimano hubs and bearings - its a fair bit thicker than that teflon stuff you have.
fwiw i use jet lube ep73 red grease.
Posted : 29/06/2013 4:42 pm
I use the Rock and roll greases
Super slick in the forks, super web in bearings and super coat on press fit stuff
Posted : 29/06/2013 4:57 pm
