Technical Help Need...
[Closed] Technical Help Needed Trek Fuel Shock Bushing
3 Users
Hi All,
After a real tough winter of riding my Trek has developed a little bit of play on its shock bushings,
See Pic
Does anybody no the size i need as a replacement ?
Where can i purchase replacements ?
Do I need an extraction tool to remove the bushing, or once I have removed the shock will it just pop out ?
Sladey
Posted : 06/04/2012 10:36 am
Assuming it's a Fox shock, Mojo will sell new bushings and top hats and they will probably know the size you need too. If they're top hat type, then the bit you can see in the photo will pop out (may need to twist and pull with mole grips or something). The bushing itself will need pushing through with a tool of some sort...probably. LBS should be able to do it for a few quid.
Posted : 06/04/2012 11:29 am
What shock is it on the bike?
I'm gonna guess it is a Fox shock.
If so you will need something like [url= http://www.ebay.co.uk/itm/FOX-SHOCK-BUSHING-TOOL-Fox-bush-tool-KaTec-bikes-/140587185644?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item20bba635ec ]THIS TOOL[/url] for removal, re-installation of the bushes.
And [url= http://www.ebay.co.uk/itm/2X-FOX-REAR-SHOCK-BUSH-DP4-Performance-bushes-fox-shock-/130532057569?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item1e645121e1 ]THESE BUSHES[/url] would be like for like replacements.
If the top hats (metal mountings) for the shock are worn you should look at replacing these as well, most good suspension tuning/repair places should be able to sort you out with them - Mojo, TFTuned, LoCo etc
Posted : 06/04/2012 11:38 am
Thanks a lot for all the advice guys
Posted : 06/04/2012 11:38 pm
