Tech question.........
[Closed] Tech question......... will it work?
7 Users
 ton
I have some cranks that take 110 bcd chainrings.
can I run 2 of these on it?
say a 30 and a 38 toother
https://www.chainreactioncycles.com/race-face-narrow-wide-single-chainring/rp-prod109723
Posted : 01/04/2019 11:25 am
With a front mech or just manually lifting the chain across when stationary?
I think you'd need ramps and pins to get a mech to move the chain from the small to the big ring.
Posted : 01/04/2019 11:27 am
 ton
I run 2 surly rings on my mtb. no pins or ramps and they shift fine.
Posted : 01/04/2019 11:31 am
 Bez
Fundamentally, yes, it'll work, assuming you're shifting by hand so that you can ensure the chain sits on the N/W teeth correctly. If you're using a derailleur then you can't use N/W rings.
The one thing you may need to bear in mind is that, depending on the rings, they may be countersunk for use on either middle or out positions, which means if you use them in the "wrong" position either you lose thread engagement or you turn one of them around (functionally not an issue with an unramped ring, just a potential aesthetic one).
Posted : 01/04/2019 11:33 am
 ton
chain is a 8 spd one, hopefully it will seat properly.
don't mind having to lift the chain rather than use a mech.
Posted : 01/04/2019 11:36 am
Shifting by hand, you’ll be fine.
My concern would be using the easier gears while in the bigger ring, as the chain will be at a fair old angle, and there’s not much room for the chain to move about on the ring, due to the thicker alternate teeth.
Might be better not using NW ones, at the expense of their benefit.
Posted : 01/04/2019 11:42 am
 Bez
Yeah, that's a fair point, you'll get a lot of rub on the wide teeth.
If you want two rings why aren't you going for two standard rings and a derailleur?
Posted : 01/04/2019 11:46 am
don't you need a 104 bcd to run a 30t ?
Posted : 01/04/2019 11:47 am
 Bez
Posted : 01/04/2019 11:55 am
CRC's clever site won't let you choose the wrong size. (If you select the correct BCD)
Posted : 01/04/2019 12:09 pm
IIRC you can get a 33 tooth 110 bcd but are quite rare, 34 is more common as the smallest.
Posted : 01/04/2019 12:10 pm
yup 33/34T is the smallest.
Posted : 01/04/2019 12:32 pm
 ton
thanks for the advice all.
Posted : 01/04/2019 12:43 pm
