Bit of a weird one:
The blue lockout knob on my revelations has stopped rotating clockwise as far as it used to. This means the fork doesn't lockout properly. It only rotates 70 degrees (ish) instead of 90.
I've taken the motion-control cartridge out but can't see anything wrong i.e. nothing obviously snapped or bent. Oil volumes are fine.
It's not the bottom compression/lockout valve on the motion-control cartridge, as I unclipped this from the red cage thingy and it moves fine.
It must be something on the upper assembly of the cartridge. Is there a way to take this apart?
Posted : 31/05/2009 6:47 pm
