Tech help: fox floa...
[Closed] Tech help: fox float 36 service
4 Users
Hi,
Just a about to take the lowers off my forks and give them a clean but can't remember the oil volume for the lower legs. They are the 2010 float r 36, not the FIT ones
Ta!
Posted : 02/11/2010 1:05 pm
 LoCo
Just got a set in the stand, 25ml in each lower leg.
Posted : 02/11/2010 1:20 pm
errr... sorry to question an expert Mr Loco, aren't the 2010 Float R's Open Bath? (aka non-fit 32 style, meaning once you drop the legs off you have to drain the cart and refill with the full 155mm)
I know the older r's were a enclosed damper (I run a 2008 set) but I thought they changed it for 2010.
Posted : 02/11/2010 1:29 pm
 LoCo
It supposed to be the Fox 'green' 10wt if you were wondering too 🙂
 LoCo
If they're open bath it 155ml in the damper side and 25ml in spring side, again fox green 10wt. 😳
The ones I had in the stand are FIT rc2 s so had that in my brain doh!
Posted : 02/11/2010 1:32 pm
Hadn't realised they were open bath, can you just slide the seals up like on 2010 FIT forks to clean and lube the foam rings?
Posted : 02/11/2010 1:53 pm
 LoCo
You can lever the seals up and clean, but I wouldn't recommend it as you've got a fair chance of damaging the seal and/or stantions if you slip with your screwdriver/lever. Best to invert the bike and take the lowers off then you can get to all of the seal and take the foam rings off to properly clean them.
Have a look at Foxy's guide, they're 32's but the priciple is the same apart from the bottom nut being a different size on the damper side below:
http://www.cyclistno1.co.uk/features/maintenance/fox-forks-wiper-seal-service.htm
Posted : 02/11/2010 2:09 pm
 hora
My 09 Floats (when changing travel)- I just angled the forks upwards, pulled off the lowers- cleaned etc then refitted with 25ml in each leg added at the bottom.
Posted : 02/11/2010 2:15 pm
