Tarting up an Islab...
[Closed] Tarting up an Islabike Cnoc 14
11 Users
So, MrsTP found a bargain Cnoc 14 on eBay, and snapped it up. "It only needs some grips and a new chain!" she cried.
It arrived earlier today, and on a brief inspection:
* both tyres are shot
* the headset is notchy
* the chain is rusted almost solid
* the (exposed) handlebar ends look as though they've been rubbed enthusiastically against a stone wall
* the front brake v-brake noodle thing is totally knackered
Hard to gauge wheel bearings and bottom bracket without a bit more dismantling, but they seem OK. The pedals felt OK.
So. I've clearly got a bit of renovation ahead of me, and I was wondering if the STW hive mind has any pointers, suggestions, gotchyas, etc when working on one of these?
Posted : 02/07/2019 5:46 pm
Can’t help that much, but what did she pay? About to sell well that really is in great condition so wondered what the going rate is 😉
Posted : 02/07/2019 7:00 pm
All sounds fairly standard, straightforward stuff. I'd also replace brake cables and blocks while you're at it and set them up to be as easy to operate as poss
Posted : 02/07/2019 7:01 pm
Normally just shy of the asking price for a new one. I can remember selling one of ours for more than we paid for it, just cause the cost of a new one had gone up. Brilliant bikes, bonkers resale value…
Posted : 02/07/2019 7:11 pm
Good condition is around £150 this week. Just sold my daughters in excellent condition. I think they go for a little more if you are prepared to post it.
Posted : 02/07/2019 7:22 pm
I flogged mine on here a few weeks back for 85 posted. It wasn't in great nick but better than what you've said. Total cost was £30 over 6 years. Total cost per child taught using it is around £2...
Anyway, your kid won't care. Chain off, petrol bath, loosen it and refit. Find a noodle in your spares box. Do inners and outers as well making sure you use those end cap things. The grips are tiny - very thin - so either fit some caps or just ring Isla for new ones which I bet are cheap. Put some grease in the headset.
FWIW I'd probably have a look at the hubs as mine were really smooth but overtightened.
Last child on mine was my 3y11m old who went through it in 2 weeks and on to a 16" Frog. They are very short lived bikes so don't waste money and (too much) effort on it.
Posted : 02/07/2019 8:00 pm
In fairness it wasn't expensive, the number that springs to mind is 38 quid collected.
Posted : 02/07/2019 8:08 pm
@Rich_s yes indeed I'm not planning to spend too much on it. New noodle and tyres (possibly tubes) will be required as I don't have spares of these. But I've got cables and outers, and I'm hoping all the bearing-y bits should be able to be ressurected with a bit of grease and TLC.
Posted : 02/07/2019 8:12 pm
So I got one in that sort of condition for £15. It was missing a brake, and the drivetrain was all completely seized.
The Islabikes online shop is pretty good - I got a brake lever and some grips for a reasonable price.
Brake cables and noodles were replaced from my garage stock.
The piece de resistance is the ‘98 Deore XT parallel push V-brakes - the envy of all the bike dads I’m sure.
As for the drivetrain and rear freehub, I took it all apart (there’s a split pin for the chain) and did a thorough clean / derust / degrease / regrease and it came out sparkling. I’m really pleased I spent the time.
So basically: give it a clean and see where you get to, then cost up the extras from the islabikes site.
Posted : 02/07/2019 8:19 pm
@Superficial thanks for that. For the chain, do you just break it as per normal on the split pin?
Posted : 02/07/2019 8:27 pm
My one had one of these type of links so you just sort of pry it off with a screwdriver and it all falls apart.
Link
Posted : 02/07/2019 10:45 pm
A set of those were to be found on my son's 16" Saracen Bolt for a long while!
Great brakes (for a non disc).
Posted : 03/07/2019 12:05 am
Having mostly stripped the bike down last night, it's not looking too bad. The worst bits are the freewheel and headset.
For the freewheel it might need a new one I think. It's a 14T Dicta and rusty/rough. I don't have a removal tool so might try ressurecting it on the bike first. But if not a tool is a fiver and a new freewheel is maybe ten pounds.
I'm currently stumped with the headset. It's gummed up and graunchy but might come back to life with a bit of grease. However, I'm not really sure how to get into it! It's a threadless headset with press fit cups. I think it has either loose bearings or bearings in a retainer but they are beneath a cover I can't get off. The cover has a little notch which I assume is for a tool but nothing I have helped with prying it off, and trying a flat blade screwdriver to pry gently from the bottom didn't get far either. Any suggestions on this?
Posted : 03/07/2019 6:57 am
If it’s a notch it usually indicates a screw thread. I have such a tool, I’ll dig out a pic.
Posted : 03/07/2019 7:49 am
I got a cheap Cnoc 16 off here a while back, needed a new chain, freewheel, brakes blocks and cables, grips, pedals, saddle and the bottom bracket needed an overhaul. I think it cost me around 50 quid in parts most of which were direct from Islabikes (pretty cheap for spares). I also had it powder coated, polished up the cranks and fitted new stickers and it's honestly as good as new 🙂
The lad loves it, though he now wants it red rather the green I had it powder coated haha.
Posted : 03/07/2019 9:52 am
@eddiebaby: thanks, you gave me a steer in the right direction! I tried rotating the cover using the little notch only to realise it was in fact a circlip-style retaining ring. Once I'd prised it out the cover came off no problem and I was face to face with the ball bearings 🙂
Sadly the bottom lot are fairly knackered and the cups rough. I've repacked it with grease to get us going but it's living on borrowed time I think!
@typer: I had searched Islabike's site but couldn't see all of the bits I was looking for. Perhaps I'll email them direct and see. Cheers 🙂
Posted : 03/07/2019 10:53 am
Isla do their own tyres now in place of the Kenda Block 8's they used to supply. They're slimmer than the Block 8's** which is a bit disappointing especially when you've only replaced one (bike now looks like a 69er). Kids like tractors for a reason you know (yeah yeah friction, rolling resistance, weight, little legs blah blah blah)!
** Couldn't find non-Isla replacements for the prescribed ETRTO anywhere
Posted : 03/07/2019 11:00 am
@tomparkin come to think of it, I'm sure it was only the grips, pedals and brake blocks I bought from Islabikes. The rest was just off ebay (chain, freewheel) and saddle from decathalon. Before and after pics below 🙂
https://photos.app.goo.gl/c8Ur3m1jxRaVm34QA
https://photos.app.goo.gl/iTBmj6TYVGVxWtjf6
Posted : 03/07/2019 8:18 pm
