Tapered fork in non...
[Closed] Tapered fork in non-tapered head tube (again, probably) ?
9 Users
Some say yes, some say no.
I've gotten a little too excited and got my hands on a nearly-new pair of forks to go on a 2003 Stiffee.
Only in the aftermath have I realised the steerer is tapered (in my defence, I started looking at new front wheels as I'm going to have to replace that too because of the dropouts).
I know there's special bottom race things you can get from Hope, Superstar & Cane Creek but I've no idea which if any would be suitable?
Time for a new frame or new forks? 😥
Posted : 08/09/2013 6:45 pm
 IA
Unless (unlikely) the stiffee is a 44mm headtube (integrated headset, i.e. the cups are INSIDE the headtube) then no, they're not fitting.
Posted : 08/09/2013 6:50 pm
AFAIK you can't get a tapered steerer to fit in a 1?" HT. You [b]can[/b] get an external cup to make a tapered steerer fit in a 44mm HT, but I'd have thought a bike from 2003 is more likely to be 1?".
Posted : 08/09/2013 6:52 pm
Stiffee only has a 1.1/8th headtube so new frame time or different forks
Posted : 08/09/2013 7:06 pm
Oh bugger. Live & learn.
Thanks chaps 😳
Posted : 08/09/2013 7:13 pm
I was just about to ask this very same question myself - gonna have a spare tapered fork in the next month or so an wasn't sure which bike it'd fit.
Looks like it's been narrowed down to the GT now.
Cheers for saving me the effort, thenorth
Posted : 08/09/2013 7:14 pm
Glad to help out!
Posted : 08/09/2013 7:26 pm
I thought crane creek did an external converter as looked at this myself. I'd have another look. Probably wrong but I only looked a couple of weeks ago.
Posted : 08/09/2013 7:35 pm
Cane creek EC44/40. Needs the bore to be 1 1/8 and will work to go with a 1 5 tapered steerer
Posted : 08/09/2013 7:38 pm
hope pick n mix. ive done mine tapered fork on a 2012 cube attention straight headtube
Posted : 08/09/2013 7:52 pm
Creedy, does that one not need an integrated headset thing rather than bog standard?
Posted : 08/09/2013 7:57 pm
That's incorrect, I'm afraid. The two letters are the cup type (in this case external), the first two numbers the headtube internal diameter and the last two numbers the steerer external diameter - see [url= http://www.hopetech.com/webtop/modules/_repository/documents/HOPEHEADSETS2011Web.pdf ]here[/url].
For a 1?" HT to take a 1.5" steerer, you'd need an EC34/40 cup, which isn't going to work.
Posted : 08/09/2013 8:05 pm
Wolfenstein, what type of head tube did you have?
Posted : 08/09/2013 8:07 pm
@thenorth. 1 1/8
Got link here ages ago when i did mine
http://www.mtbe.co.uk/tapered-fork-on-non-tapered-frame-t30197.html?highlight=tapered
Posted : 09/09/2013 3:58 pm
 IA
Wolfenstein - that's not a standard 1 1/8th headtube, it's a integrated headset one as mentioned above (so 44mm).
Posted : 09/09/2013 4:04 pm
that link is for a 44mm headtube, not 1 1/8.
My mistake then tbh. I though its the same or my understanding is wrong all along 😯 ..anyhoo.. Its kinda done like that : ...what is 1 1/8 looks like by the way?
Posted : 09/09/2013 4:06 pm
thenorth - Member
wolfenstein - Member
@thenorth. 1 1/8
That's your steerer size not your head tube size. Have a look on park tools website or [url= http://www.canecreek.com/headset-fit-finder ]cane cree's website[/url] for more info on finding out what head tube you have.
Posted : 09/09/2013 4:16 pm
