Tandem bottom brack...
[Closed] Tandem bottom bracket/crank woes
5 Users
Looks like the bottom bracket has come apart, there is a ton of play and you can see the bearings. It is square taper so I tried to remove the rear drive side crank arm with a crank puller but it stripped almost all of the threads out while not budging the crank at all. What can I do to resolve this?
Posted : 19/03/2013 7:24 pm
Not really anything tandem specific in what you're doing - even the rear driveside crank isn't (which makes replacement a lot cheaper).
Very hard to tell without seeing it, but I'd be suspicious that there's some washer in there you've missed - that or you're using a splined crank extractor. Three standard methods I can think of to remove that. Take it for a ride, doing lots of standing up (but stop as soon as it gets loose). Use a 3 or 4 legged puller. Use a hacksaw / dremel.
Posted : 19/03/2013 7:35 pm
Make sure you use a good quality crank puller like a park one. Cheapo ones have shallow threads and pull out easily, taking some of the extractor threads with them.
I managed to rescue a set of cranks using a park one before.
Posted : 19/03/2013 7:47 pm
Was the bolt in the puller screwed right out before use ?
A big bar, positioned at the base of the arm at the rear & a smart wack with a good hammer will see it fly off.
Posted : 19/03/2013 7:48 pm
to be fair to the OP, if its been on a while and was sparse on the grease originally its entirely possible to strip the threads out of cranks trying to take them off. Usually resort to some sort of fly-wheel puller, requires a bit of finess to get the arms to stay on but should get the arm off. Bit of heat (watch the paint) and a bray with a metal hammer to shock it into loosening will help too.
Posted : 19/03/2013 7:55 pm
Zip ties and/or tape helps a lot with this.
Posted : 19/03/2013 8:02 pm
Yeah the puller was in all but the very last part of the thread so theres basically none of it left now! I'll try some of these tips, thanks!
Posted : 19/03/2013 8:05 pm
