Tall quill stem on ...
[Closed] Tall quill stem on a threadless fork?
5 Users
 ton
is there a safe way to fit a tall quill stem (nitto technomic) to a threadless fork?
Posted : 30/01/2015 10:38 pm
The problem you have is tensioning the headset before installing the fork.
I am building a bike for a disabled guy and I needed a very high rise stem. I've gone for an adjustable one - BBB HighFix - but they do creak a bit sometimes.
Have a look at Humpert stuff - they do loads of stem of all types including ahead ones - maybe something like this on top of a long steerer - http://practicalcycles.com/products/242534--humpert-high-charisma-ahead-stem-1-18-inch.aspx
Posted : 30/01/2015 10:54 pm
I'm not sure that there is such a thing (this statement now guarantees that there is a safe solution 🙂 )
You can go the other way and convert quill to threadless, but that isn't what you want
Posted : 31/01/2015 4:45 am
If the stem and steerer are the same diameter, it's theoretically possible but not advisable.
If the stem is 1" and the forks 1 1/8" then it's possible but still quite a bit of work involved, and it won't be very pretty.
Posted : 31/01/2015 7:57 am
You get adjustable headset spacerswhich negate tbe need for a sfa or top cap.
One ofthose would allow you to use a quilstem provided the inner diameter is correct?
Posted : 31/01/2015 7:58 am
