Talk to me about Ho...
Talk to me about Hope Pro 2 Evo hub compatibility
6 Users
6 Reactions
Existing Hope Pro 2 Evo hubs F+R, is it possible to get them to fit a 12 speed shimano cassette (105 R7100 11-36) and also to fit 12mm bolt thru axles (100x12 front and 142x12 rear)? If so, what adaptors do I need?
Thanks!
Posted : 16/03/2024 4:41 pm
Pro 2 Evo or pro 2 Evo 40t rear? Latter will accept a free hub that will take a road cassette. Don't think the former will. Both can goto 142x12. Front will do 100x12, same adapter as pro 4 iirc.
Posted : 16/03/2024 4:47 pm
Houns and Houns reacted
Pro 2 Evo, if it helps ID they’re the limited edition pink ones. Can you change freehub body?
Posted : 16/03/2024 4:55 pm
Adaptors will work but you’d need a 12 speed road freehub. Not sure they make one for such old hubs.
Actually, just had a look and seems the 12 speed also fits 11 speed hg freehub, so you should be ok.
Posted : 16/03/2024 4:56 pm
HUB493 looks like it’s the one I need for the rear
Posted : 16/03/2024 4:58 pm
Use hub231 has an X in the spec for 142mm
231 is for the Pro2? Mine are the Pro2 evo
Posted : 16/03/2024 5:02 pm
Hub493 is boost spaced (148)
Posted : 16/03/2024 5:03 pm
Ah gotcha, thanks
Posted : 16/03/2024 5:04 pm
Hub242 for the rear. Very bottom of the link I posted says X12 to convert 135 to 142.
Hub482 for the front
Posted : 16/03/2024 5:06 pm
Not if you want 142 by 12mm, HUB493 is the boost conversion kit.
For what you asked for, 100×12 front and 142×12 rear, I think you need HUB482 on the front and HUB242 on the rear. No idea about road cassettes, check what Nixie says as he's probably right.
Edit: Beaten to it.
Thanks all. Hmm the expense of getting wheels rebuilt (with new rims and having them converted) is looking similar cost to buying a new factory wheel set.
Posted : 16/03/2024 5:21 pm
The tech guys at Hope will tell you. It always amazes me when you can ring a business and talk to people.
Posted : 17/03/2024 8:12 pm
