Talas to Float conv...
[Closed] Talas to Float conversion help...
3 Users
Hi,
Not sure if anyone can help but I have bought the conversion kit from Mojo.
Just wondering in the spring side there is a rubber washer type thing in the bottom of the lower leg. Does anyone know if this still needs to stay in the leg as part of the conversion or do I take it out? I have a new aluminium washer to go in.
I can't find any documentation on how it should e done.
Thanks for any help 🙂
Posted : 22/08/2013 5:39 pm
I've done this conversion on a set of 36 Talas and I don't remember an aluminium washer, according to Mojo the kit contains
airshaft x1 - Float Topcap x1 - Negative Plate x1 - Base Nut x1 - Crush Washers x2
No mention of an aluminium washer 😕 .
Posted : 22/08/2013 6:21 pm
The aluminium thing came as part of the kit it's a sort of cup thing. It's more the rubber washer in the bottom that I was worried about but I'm guessing it stays in and think it might be a bump stop....
Maybe the kits are different.
Posted : 22/08/2013 7:31 pm
There is a pic of the aluminium cup thing here: http://www.mojostore.co.uk/acatalog/Conversion-Parts-1.html
Just in case anyone thought I was going mad 🙂
Posted : 22/08/2013 7:34 pm
