Hi,
I squirted oil into my Juicy 3 levers and they no longer spring back after being pressed. I suspect the seals have swollen and this is what's causing the problem. If I dismantle the lever, clean all the seals and grease with the right lube, is it likely to solve the problem? Or will new seals be required?
The brake system was working fine prior to this and had been bled fairly recently.
Thanks.
New seals, and a very thorough clean up of everything else using a brake cleaner or similar, if you skimp on the clean up you'll end up in the same boat again.
and you can use silicon spray rather than oil or GT85 once sorted - use this all the time now on Hope's and Shimano levers
indeed, that should do the job 🙂Thanks iainc, I bought a can of this today, would it be suitable?
Once they've swollen it just gets worse, leave them long enough and it'll turn to something resembling chewing gum.
Thanks [b]coatesy[/b], sounds like I need to bite the bullet and sort the seals out.
I had the same problem and got new seal kits from UKBikeStore iirc. Brakes work a treat now.
All brakes are liable to fail and cause grief sometimes
Juicys take the piss tho
Thanks everyone.
With my lever in pieces the seals don't look too bad. What would be the best thing to clean the internals with in order to get rid of the oil? Degreaser? Hot water and washing up liquid?
Been using Muc-off Brake Cleaner with good results, but wear safety glasses and beware of blow-backs as it's pretty high pressure and will sting if it gets in your eyes.
