switching mounting ...
[Closed] switching mounting hardware from an RP23 to a Monarch R ,straightforward swap?
2 Users
Hi ,
I got a very good offer of a RockShock Monarch to replace a fox float RP23 which has blown a seal behind the propedal knob .
The Monarch will cost me much less than the rebuild of the rp23 .
What I am wondering is if it will be easy to pop the mounting hardware off the fox and into the monarch ? are those bushing sizes interchangeable ?
Thanks for any pointers ,
J
Posted : 21/09/2017 8:30 am
Should be the same. Replaced worn bushing on a Monarch RT with ones I had lying around from an RP23 and same fit. The mount hardware then is basically the same. I'm using the TF heavy duty kit I had for the RP23 with the RT.
Posted : 21/09/2017 9:13 am
