Swapping SS chain r...
[Closed] Swapping SS chain ring - do I need to change the chain & sproket as well?
4 Users
As per the post- if I change my ratio for some SSCX action do I need to/ is it best to change the sprocket and chain?
Posted : 01/08/2016 9:09 am
Obviously you'll need to lengthen / shorten the chain. Otherwise, unless it's all knackered, i probably wouldn't bother replacing anything other than the chainring.
It'll soon let you know if it's upset.
Posted : 01/08/2016 9:14 am
not if they are fine and dont need changing
Unlikely the chain be the same length - ie 32 is smaller than a 34 but a doofer may take up the slack if going smaller - less teeth may need longer chain if going up - dont know i Have an ECB and have only ever run 32:16
Depends really but if neither is wor no need to replace.
Posted : 01/08/2016 9:15 am
A SS sprocket has deeper, non-ramped teeth so will run a lot smoother and wear better than simply using a cassette sprocket that will wear quicker. A SS sprocket and decent 6/7/8 speed chain will only be £10-15 and will probably last twice a long and reduced chance of breaking.
Posted : 01/08/2016 9:25 am
Cheers everyone; whilst the chain and sprocket look good I think I will buy a chain ring, chain and sprocket for a mighty cost of £21.47!
Posted : 01/08/2016 9:37 am
