Swapping front whee...
[Closed] Swapping front wheels between Pro2 & Pro3SP,will brake need adjusting each time?
7 Users
Currently got a very heavy front wheel for DH stuff, with a hope pro 2 evo hub.
I'd like to get a lighter front wheel for trail days, was going to buy a Pro2/Flow front wheel so that there would be no alignment issues with the disc/brake (Formula oro)
If I got the Pro3 SP with disc do you think there will be any slight alignment issues each time I swap?
Any idea of the weight saving from Pro3 SP with disc over standard Pro2 hub and disc?
Ta
Posted : 28/11/2011 6:07 pm
 flow
Sell both pairs and buy something suited to a bit of both would be the obvious answer.
Also why do you have a heavier hitting wheel on the front, when pretty much all of your weight is at the rear?
Posted : 28/11/2011 6:13 pm
I've only got one pair of wheels. Tough ones
The wheelset was built for trip to Whistler, I like downhilling and big jumps so still want a tough front wheel for that kind of stuff.
Posted : 28/11/2011 6:19 pm
i'd go for a set of lighter tyres.
Posted : 28/11/2011 6:21 pm
 flow
In that case sell the pair of wheels you have and buy something more suited to the UK.
Flow Hope Hoops would be fine for what you want.
Posted : 28/11/2011 6:30 pm
Hopefully someone can answer my simple question
Posted : 28/11/2011 6:31 pm
It only take a few seconds to adjust the front brake.
My Hope Pro2 and Hope Pro3 SP AM4 aren't aligned exactly the same. I have to adjust the brake slightly most times I swap them.
Posted : 28/11/2011 6:35 pm
Thank you neninja
Posted : 28/11/2011 6:36 pm
[url= http://www.syntace.com/index.cfm?pid=3&pk=757 ]These are pretty handy for what you're looking to do...[/url]
Posted : 28/11/2011 6:37 pm
Posted : 28/11/2011 6:39 pm
As above, with post mount brakes - loosen caliper bolts, pull brake on and hold it while retighten bolts. I'd say your bike probably isn't light though, so you would benefit from the sp3. I switch pro 2 wheeels routinely without brake issues - front and rear.
Posted : 28/11/2011 6:42 pm
As long as the Pro3 SP disc is further out to start with than the Pro2 mounted disc, as the Pro3 SP with Flow rims has a 4 bolt disc pattern so that shim won't fit.
Posted : 28/11/2011 6:45 pm
