Swapping flow ex to...
[Closed] Swapping flow ex to mk3
4 Users
so ive got a 26" crest and im thinking of swapping it to a mk3 rim. (wider is better etc)
will i need new spokes? If so how long would they need to be? You can tell ive not done this before.
Posted : 13/02/2018 2:07 pm
I think they will be ok
but look at the ERD numbers - they must be somewhere on the interweb
if they are similar you will be fine
Posted : 13/02/2018 2:22 pm
 DrP
So I'm going to swap from Arch EX to Flowm Mk3 (29er)..the ERD is the same, so can jsut swap spokes. However, i'd still check your rim-rim ERDs...
DrP
Posted : 13/02/2018 2:25 pm
Check ERD, if its the same you are good to go, I would fit new nipples.
De tension, tape the new rim onto the old one and swap the spokes over 1 at a time, tension/true/dish
Posted : 13/02/2018 8:12 pm
