Swapping 10sp for 1...
[Closed] Swapping 10sp for 12 - Any Watch outs?
8 Users
I want to swap my 10 sp cassette on one bike for the 12 speed that is on the other bike. Both wheels are DT Swiss so I am thinking it is simply just swap the cassette, freehub, mech, and shifter from one bike to the other??? Anything I am missing, and anything that might catch me out and render both bikes useless when I need one at the weekend?
Posted : 04/10/2021 5:32 pm
Chain and chainring compatibility?
Posted : 04/10/2021 5:35 pm
The front chain ring is a boost shimano on both bikes and cassette that I am transferring over (along with chain) are also Shimano. Hmmmm only thing might be chain length as the bikes are slightly different in length????
Posted : 04/10/2021 5:39 pm
Freehub - 10sp will be old style Shimano. 12 speed could (will?) be microspline or XD driver.
ETA apols, you did mention freehub.
Posted : 04/10/2021 6:01 pm
Isn't there a Sunrace 12sp cassette that doesn't need a Microspline freehub?
Posted : 04/10/2021 6:18 pm
Any reason you can’t just swap the whole wheel?
Chain length could be the only issue that puts a fly in the ointment
Posted : 04/10/2021 7:25 pm
Make sure your mech hanger alignment is bang-on - 12 speed is really sensitive to this.
Posted : 04/10/2021 8:40 pm
If only I could just swap wheels, it wouod be so much easier. 29/27.5, maybe I could mullet it 🙂
Thanks all, will give it a bash and keep everything crossed
Posted : 05/10/2021 12:04 am
Ah, I didn’t mean chainline (boost or not), I mean does the 12 speed chain play nicely with the teeth on the older chainring, if you’re not swapping the ring/chainset over with everything else? They tend not to.
Posted : 05/10/2021 12:11 am
That’s a very good point and one I hadn’t considered. I suppose I could swap the cranks over as well, considering everything else, that would be the easier part of the task.
Posted : 05/10/2021 12:24 am
On my sons bird Aeros mk1 the derailleur fouled on the chain stay pivot with 12 speed due to the 10T smallest sprocket. Got round it by messing with the b tension but it was always a bit crap.
Posted : 05/10/2021 12:31 am
Coincidentally both bikes in question are Birds
Posted : 05/10/2021 12:33 am
I would.
Posted : 05/10/2021 12:52 am
Are shifters both bar-mount or i-spec?
Might be different i-spec types?
Posted : 05/10/2021 10:53 am
Both bar-mount but good point!
Posted : 05/10/2021 11:57 am
