Swap out SRAM Guide...
[Closed] Swap out SRAM Guides for Codes
5 Users
Going to swap some Guide Ts for Code Rs for a mate. Any reason why I can't swap the caliper and levers and leave internally routed hose in situ
Thanks for helpful answers in advance.
Posted : 26/10/2020 1:51 pm
Not sure if the caliper end hose hardware is the same or not. Lever end yes fine.
Posted : 26/10/2020 2:33 pm
I think it'll work, you'll need new olive and barbs though.
Posted : 26/10/2020 3:17 pm
Or if you want / need to swap the hoses, use on of the red hose connectors you get with a reverb to attach one hose to the other and then pull through.
Posted : 26/10/2020 5:04 pm
My rsc codes have different caliper connectors than my guide rsc.
Posted : 26/10/2020 5:07 pm
Thanks all, went for it. The banjos are slightly different in appearance / construction, but the thread / length appears the same. The Code hose was too short, so that forced the issue.
<span style="font-size: 0.8rem;">Needed to replace the lever end barb / olive, as had to cut the old one off to change the rubber covers as they were different size.</span>
Will see if he dies next time out....
Posted : 26/10/2020 5:26 pm
