Suspension issues! ...
[Closed] Suspension issues! Rockshox
2 Users
Hi guys, I brought a nukeproof mega am 2012 a few months ago now and ride it pretty much twice a week when I can. I took it for a service at my LBS and all was good. It had a small problem with the rock shox monarch rt3 shock that was slowly leaking. All was fine when I got the bike back for a few days and rode it fine. After about a week though I have noticed a few more problems. The shock still leaks but they only gave it a service about a week ago (replacing all seals etc) and a pressure test. So that's the first thing I need help with. Then there's the other issue. I have started to notice a knocking from the fork which is 2012/13 (I think) rock shox lyric coil u turn. It knocks form the damper I think, when I hold the front brake on and rock the bike slightly. I thought nothing of it at the time and probably didn't notice it before I got the bike serviced because of the wheel bearings and headset being replaced. But this morning I when the into the shed and found a pool of fluid under my forks. It appears that fluid is leaking form the rebound adjuster bolt. Could it be that a seal has gone or that the damper has failed ? And help would be much appreciated. Cheers
Posted : 02/01/2016 11:13 pm
It could be, yes, but also there should be a seal around that bolt.
*Bump*
Posted : 03/01/2016 8:12 am
Ok great cheers
Posted : 03/01/2016 10:51 am
