Superstar I/0 Narro...
[Closed] Superstar I/0 Narrow Wide... are they threaded?
10 Users
Hi Chaps,
Are the Superstar Narrow Wide rings threaded, or do you need short bolts?
The photos have both....
Ricks
Posted : 11/02/2015 6:56 pm
Mine isn't threaded
Posted : 11/02/2015 6:57 pm
Neither is mine (32t)
Posted : 11/02/2015 6:59 pm
My 32t isn't.
I didn't get shorter bolts either, just ground the ones I had down quite a bit (wear gloves or use molgrips)
Posted : 11/02/2015 7:01 pm
i bought a race face one , well three, and they all were which i think is a brilliant idea.
Posted : 11/02/2015 7:06 pm
Yep, was just confused as the photo shows both. Threaded is a much better solution, I've got short bolts that I've got on my Hope retainer.
Posted : 11/02/2015 7:18 pm
Think only the 30t is threaded.
Posted : 11/02/2015 7:28 pm
Only 30t is threaded, as it need to be offset from the crank slightly, as it's too small to bolt on without the tabs fouling the chain otherwise.
Posted : 11/02/2015 7:32 pm
What honorablegeorge says
My 30t was threaded. 32 t wasnt
I had some fat washers for the 32 and used standard bolts
Posted : 11/02/2015 9:06 pm
I just want to add that 30t is threaded.
Oh, and 32t isn't.
Posted : 11/02/2015 9:10 pm
 rob2
I'll +5 that 30t is threaded 🙂
Also I needed some washers to space it out to stop it fouling on the crank (xtr 970)
Posted : 11/02/2015 9:12 pm
I have it on good authority that the 30 is threaded.
Posted : 11/02/2015 9:33 pm
