Hi guys anyone used this? Did it work? I just tried it and it knocked the bearings out of the cup sweetly but not the cups out of the shell.
I emailed ssc to see if there was something I was doing wrong.
They said that the bearing are usually pressed into the cup tighter than the cups are pressed into the frame??? Thoughts please. And that I should then use a headset remover to get the cups out. Then shouldn't I just get one of those things instead?
Posted : 01/08/2012 6:04 pm
