SunRace Mech and Sr...
[Closed] SunRace Mech and Sram shifters?
5 Users
Anyone tried Sunrace rear Mech and a Sram shifter?
I currently have a 10 speed Sram GX setup, with a SunRace 11-42 cassette. All OK, but the Mech is getting oldish and will one day soon give up.
The Sunrace MX mech is 10/11/12 speed compatible with the matching SunRace shifter, so say the distributor. Has anyone paired the SunRace Mech with a 10 speed Sram shifter?
Plan is to replace my current GX Mech with the sunrace MX (~£79), and as and when the cassette needs replacing, go for a 12 speed SR one and shifter.
Will I die?
Posted : 27/07/2019 3:36 am
Sorry, can't help on compatibility but I'm sure there's a thread on here outlining some reliability issues with the Sunrace mech. Basically the pivot the cable attaches to has a tendency to snap off.
On top of that you have to remove the mech on some frames in order to get the wheel out....
A search should throw the thread up and no doubt someone will be along on this thread to double check my memory isn't playing tricks on me.lol
Posted : 27/07/2019 3:41 am
Righto, not so simple a choice then.
Maybe wait until the shimano 12 speed trickle down is hitting the sales pages!
Posted : 27/07/2019 5:49 am
I think the mech ratios are a bit diff at 10 speed (between Sram and Shimano). And Sunrace follows Shimano. I can't remember where or how I got this idea from though.
Posted : 27/07/2019 6:27 am
I ran the sram X1 11 speed shifter with Sunrace MZ80 rear derailleur it works but have to fiddle a bit with limit screw to get smooth shifting, also did it with XX1 12 speed shifter although now running XX1 rear derailleur too
Posted : 27/07/2019 7:14 am
 kane
I tried it with a sram gx 11sp shifter and a hope cassette because the sram mech wasn't coping well with the larger cog on the cassette. It worked but wasn't as crisp as the sram in the higher gears so I took it off.
You're welcome to have my mech for postage if you want to try it.
Posted : 27/07/2019 9:02 am
@Kane, that very kind of you, I'll certainlly take the mech for just postage, worth giving it a try! I've sent you a PM.
Posted : 27/07/2019 8:11 pm
