has anyone fitted one of these? If so how many spacers were included in the box? I feel it needs a 1mm spacer between the 2 aluminium gear housing but nothing was included.
Thanks
None came with mine ...
None with mine either. Works perfectly as it is.
Not sure what you mean by "between the 2 aluminium gear housing", but no extra spacers included or needed.
My mx8 has one red spacer. Can't remember exactly which sprockets it goes between but you definitely need it.
Not sure where you are referring to but my 11-46 MX8 came with all spacers needed.
Just fitted what came with mine and it all works well.
Thanks guys, the problem I have is between the first spider and the second spider as they fit on the freewheel hub. Â There in not enough space between the 3rd and 4th gears for the chain to drop onto the 4th gear properly..if I fit a 1mm spacer between the 2 spiders then everything is ok. Â The red spacer included is fitted further down the cassette and all other gears are fine. Â The drawing on their website suggests there are 2 spacers included in the box, not the 1 in mine.
