I'v got a set of charger expert 29er wheels and the front bearings have loads of play . i have no idea which hub its or bearings fit it or the number you seem to need to order any replacements or who's best to order from 😳
help and recommendations please
You need to take the hub covers off and see if you can read the bearing size off the seals. For the rear you'll probably need to drift all the free hub bearings out to workout what sizes that are. BETD is good for bearings.
thanks for the reply , had look and their 6804 rs and iv ordered some off flea bay .
CheesybeanZ - how long did your bearings last? I've just ordered some bearings from KaTec on ebay as they are meant to be slightly better sealed/greased as I've had nowt but problems.
5 months , not great and i covered them with a good quality grease from new . I'm surprised the fronts gone first tho .
Been through 3 sets in 8 months on the rear. Front have been fine so far. Just covered mine completely in grease too so fingers crossed. The RS bearing seals make a difference against the RU seals
3 sets in 8 months !!! i did a forum search and seems the bearings let the wheel set down . did you get them replaced under warranty ?
