Stupid UST Wheel qu...
[Closed] Stupid UST Wheel question
8 Users
Ok - I'm new to this UST malarky and have UST rims on my bike. Do I [i]have[/i] to buy UST tyres or will any tyre work?
I'm assuming I need sealant in there anyway - but just wondered whether my tyre choice was restricted or not.
Thanks.
Posted : 02/05/2012 2:13 pm
UST tyres will usually seal easiest and have more durable/beefy sidewalls.
Regular tyres can work too but it's a bit hit and miss and they are moer vulnerable.
Def use sealant.
Posted : 02/05/2012 2:14 pm
Complete pot luck based on rim and tyre,ply etc. Tubless ready and toobliss will obviously work. Most dualy ply maxxis ime have worked fine too.
Posted : 02/05/2012 2:16 pm
Thanks Al.
I was looking for mud tyres for the weekend but there seems to be stuff all choice in tubeless. I may need to risk it.....
I've had cheap contis work well, an NBX and a Swamp thing too.
Some door frame sealant in teh well of teh rim helps provide the intial seal you need...
Posted : 02/05/2012 2:38 pm
Bonty Mud-X will be fine.
UST rim with a UST tyre isn't supposed to need sealant, but it's better with it. Just doesn't need it to seal the bead. I prefer UST tyres as the sidewalls are stronger.
Posted : 02/05/2012 2:48 pm
(Just getting over very basic presumption, that you want to run tubeless - standard tyres will work with tubes.)
If the wheels are UST, then you can use UST or some of the Tubeless Ready variation (Bontrager Mud-X, Schwalbe, Specialised, etc - you'll need a sealant for this type, but it's also recommended/good idea as a backup to run with a true UST setup).
Running non tubeless/-ready tyres aka Ghetto needs more info (search on forum to pitfalls, methods and suitable tyre/rim combinations)
If you haven't tried to run tubeless these wheels before as tubeless, make sure that they are a true UST and don't require either additional specific rim strips or valves - make sure you order these before changing tyres & flying out the door on a ride/trip.
Bonty Mud-X great choice as TLR (Tubeless Ready) tyre & remember pressures can be run a few PSI lower aswell (to paraphrase a post earlier this week - tyre should feel like you were squeezing an orange rather than an apple).
Posted : 02/05/2012 2:50 pm
Spesh storm control toobliss or maxxis medusa ust.
Posted : 02/05/2012 3:04 pm
They are proper UST wheels - so it does sound like I've got some options as long as I do a bit of research and use sealant.
I was looking at Panaracer Fire Mud tyres as I've used these before and really got on with them. I know I could just take the valve adaptor out and shove a tube in but I'd rather run tubeless if possible.
Posted : 02/05/2012 3:33 pm
 vala
I've got some Stan's flow that I run with normal single ply high rollers. Does the job fine.
Posted : 02/05/2012 4:00 pm
Lots of UST tyres (Maxxis, Kenda) state you musn't use sealant and it voids the warranty.
Posted : 02/05/2012 4:17 pm
Depends a bit on the sealant, but I had a large egg-shape lump come up on the side of a Maxxis UST tyre which I blame on Slime sealant delaminating the tyre, I think the Notubes stuff is OK though - at least, not had any problems so far...
Definitely use sealant, though - it won't completely eliminate punctures, but you'll really have to slam the wheels onto the square edge of a rock, or slash the tyres to have a problem.
Posted : 02/05/2012 4:38 pm
