Stupid pathetic dum...
[Closed] Stupid pathetic dumbass tubeless question....
11 Users
So why do I need to use Stans special tape on a Crest rim? What's wrong with insulting tape? I'm putting an Advantage on & theyr'e a really slack fit.
I'm guessing that leccy tape is too 'soft'?
Posted : 07/07/2012 3:37 pm
Yeah, stans tape is proper tough stuff. I've heard of people using other stuff, but I dunno if electrical tape would work.
Posted : 07/07/2012 3:44 pm
 IA
Insulating tape stretches, wouldn't hold pressure over the spoke holes. Stans tape doesn't stretch.
Posted : 07/07/2012 4:02 pm
Insulating tape will work, but you will need 3 or 4 layers. This might help with Advantages.
Posted : 07/07/2012 4:05 pm
Insulating tape does work... But you need multiple layers, and it might not be as wide as the rim. Also, it's more likely to damage- it's quite easy to push it inwards on the rim as you change tyres. To be fair stans tape can do that too but it's much rarer.
Posted : 07/07/2012 4:07 pm
Electrical tape works fine with a tubeless valve.
I've done it that way for years, normally 2 or 3 runs round & it's good to go. Never had an issue 🙂
Posted : 07/07/2012 4:30 pm
I'll give it a go, What's the worst that can happen!
Posted : 07/07/2012 4:32 pm
I'm with Hobnob here. Can't believe the tightwads on STW spend money on stans tape when there is a cheap workable alternative!
Posted : 07/07/2012 4:33 pm
[i]Can't believe the tightwads on STW spend money on stans tape when there is a cheap workable alternative![/i]
I think we (the one's who use leccy tape) are the tightwads! 😉
Posted : 07/07/2012 4:41 pm
does anyone know if you still need notubes rim tape if the rim is a usb one (so no holes drilled on the inside for spokes) and the tyre is a normal one but being run tubeless?
Posted : 07/07/2012 4:49 pm
Rim tape is only for sealing the spoke holes, so if you don't have spoke holes, you don't need tape.
Posted : 07/07/2012 5:16 pm
I've bought and use Stan yellow tape, however I'm back to using the 3M filament tape I originally bought as it was what Stan recommended using in his original ghetto tubeless instructions (I went tubeless before kits were available). Seems to work just as well. [url= http://www.ebay.co.uk/itm/MONOWEAVE-FILAMENT-TAPE-2-ROLLS-50MM-X-50M-FREE-POST-/150433270167#ht_989wt_1037 ]This stuff[/url] with fibres just in one direction - I've seen people suggesting the cross-weave stuff which may work as well, but not as easy to split to the exact width you want.
Posted : 07/07/2012 9:29 pm
Last time I did one I used one layer of insulating tape. A while later I had cause to change the tyre and looking at the tape, it had deformed inwards on the spoke holes quite alarmingly. Added 2 more layers & still need to re-do the other rim, though it's been holding up so far...
Posted : 08/07/2012 12:05 am
Insulation tape works fine, duct tape works fine, hell you could probablt use sellotape but it it's probably not sticky enough. Once round will do with the other stuff.
Posted : 08/07/2012 12:23 am
